Is Griffiths' formula for electric dipole radiation correct?
The discussion revolves around the validity of Griffiths' formula for electric dipole radiation, particularly in the context of its derivation from the Biot-Savart law and the implications of using a non-uniform current. Participants explore the theoretical foundations of the formula, its assumptions, and the conditions under which it may or may not hold true.
  • One participant questions the appropriateness of using Griffiths' formula derived from Biot-Savart law, noting that it assumes an infinite and uniform current, which does not align with the scenario presented.
  • Another participant clarifies that the formula in question is the retarded potential, which can be derived from Maxwell’s equations using Green’s functions, rather than being strictly Biot-Savart.
  • Some participants express confusion over how Griffiths' derivation can be valid when starting from Biot-Savart, given its limitations regarding current uniformity and extent.
  • A participant mentions that it is not necessary to start with Biot-Savart, suggesting alternative derivations exist.
  • One participant discusses the approximation of the Maxwell-Ampere equation for small frequencies and amplitudes, indicating that under certain conditions, Griffiths' approach may yield a good approximation.
  • Another participant introduces a more complex treatment involving a harmonically oscillating charge and the continuity equation, emphasizing the importance of charge conservation in deriving electromagnetic potentials.
  • Concerns are raised about whether the addition of the retarded time term is sufficient to validate the use of a formula based on uniform, infinite current distributions.
Participants express differing views on the validity of Griffiths' derivation and the assumptions underlying it. There is no consensus on whether the formula is universally applicable, and multiple competing perspectives remain regarding its derivation and implications.
Participants highlight limitations related to the assumptions of uniformity and infinite extent of current in Griffiths' derivation. The discussion also touches on the conditions under which approximations of the Maxwell-Ampere equation may hold true, indicating that the validity of the formula may depend on specific scenarios.
Silviu
Hello! I am reading Griffiths derivation for the electric dipole radiation (actually my question would fit for the magnetic dipole radiation too). He considers 2 charged balls connected by a wire with charge going back and forth between them. Now, when he calculates the vector potential he uses this formula: $$A(r,t)=\frac{\mu_0}{4 \pi}\int_{-d/2}^{d/2}\frac{-q_0\omega sin[\omega(t-r'/c)]\hat{z}}{r'}dz$$
However, if I followed it properly through the book, this equation is derived from Biot-Savart law (and a proper choice of gauge). However, when introducing Biot-Savart, Griffiths emphasizes that the current density (or linear current in this case) must be infinite in extent i.e. started infinitely long in the past and uniform. However the current is not infinite in extent, nor uniform. I see that Griffiths takes into account the fact that the potential is retarded, but I am just a bit confused about using this formula derived from Biot-Savart. Is it that obvious that a formula based on a uniform, infinite in extent current is correct just by adding that ##t-r/c## term?
That formula is not Biot Savart, although it looks similar. It is the retarded potential which can be derived from Maxwell’s equations in the Lorenz gauge by using Green’s functions.
Thank you for your reply. I know it is not Biot-Savart. What I was saying is that Griffiths uses Biot-Savart to derive it. His approach is to Biot-Savart to prove that ##\nabla \times B = \mu_0 J##. Then, using ##B=\nabla \times A ## and the gauge in which ##\nabla A = 0## he reaches the formula I sated above. My confusion is that in his approach the starting point is Biot-Savart. However, as he specifies, Biot Savart is for the case of a uniform current, of infinite extent. So why does this retarded potential formula holds, even if its starting point wouldn't hold in the case of a non-uniform current.
I can’t say anything about his specific derivation, but it is not necessary to start with Biot Savart. There are other derivations.
Ignoring , for the moment, how he arrives at ##\nabla \times B = \mu_0 J## (1), this equation is almost the full Maxwell- Ampere equation (which hold in any case of current density), it just misses a term ##\epsilon_0\mu_0\frac{\partial E}{\partial t}## (2) in the right hand side. For small enough frequencies and amplitudes of the electric field (for example smaller than ##10^{8}## cause the term ##\epsilon_0\mu_0## is of the order of ##10^{-16}##) we can take (1) as a good approximation of the full Maxwell-Ampere law so it holds approximately.
The trick is that you have an indealized charge-current distribution which makes the exact retarded solution very simple. The general case is much more involved. I've just developed a nice treatment of the Hertzian dipole for my E&M lecture. The idea is to start with a harmonically oscillating charged particle, and it's most convenient to use the complexified treatment, i.e., one makes all the fields complex valued and understands as the physical values its real part. Then we consider a point charge harmonically oscillating along the 3-axis with angular frequency ##\omega##, i.e.,
$$\vec{y}(t)=d \vec{e}_3 \exp(-\mathrm{i} \omega t).$$
Then the charge-current distribution is given by
$$\rho(t,\vec{r})=q \delta^{(3)}[\vec{r}-\vec{y}(t)], \quad \vec{j}(t,\vec{r}) = q \dot{\vec{y}}(t) \delta^{(3)}[\vec{x}-\vec{y}(t)].$$
It's crucial to note that this obeys the continuity equation (charge conservation):
$$\partial_t \rho + \vec{\nabla} \cdot \vec{j}=0.$$
If you'd use this to calculate the scalar and vector potentials of the electromagnetic field, you'd get the Lienard-Wiechert potentials, but that's a pretty cumbersome calculation.
Instead the idea is to assume that ##d \ll \lambda##, where ##\lambda=2 \pi c/\omega## is the wavelength of the radiation expected to be produced by the harmonically oscillating charge. Then, if you look at the fields not too close to the origin of the coordinate system, it's justified to expand the charge-current distribution in powers of ##\vec{y}## and ##\dot{\vec{y}}##. It's important to make this consistent such that the continuity equation holds at each order. The first non-trivial order is the expansion up to order ##d##, i.e.,
$$\begin{split}
\rho&=\rho_0 + \rho_1=q \delta^{(3)}(\vec{r}) - q \vec{y}(t) \cdot \vec{\nabla} \delta^{(3)}(\vec{r}),\\
\vec{j} &= \vec{j}_1=q \dot{\vec{y}}(t) \delta^{(3)}(\vec{r}).
\end{split}$$
Indeed, using this approximation for charge and current densities still obeys the continuity equation exactly, which is crucial to get physically meaningful results for the em. field.
The first term ##\rho_0## is just the static (time-averaged) charge distribution of a point charge ##q## sitting at the origin. Integrating this with the retarded potential leads to the corresponding Coulomb potential in Lorenz gauge, i.e.,
$$\Phi_0(t,\vec{r}) = \frac{q}{4 \pi \epsilon_0 r}.$$
The next order is indeed electric-dipole radiation (i.e., the ##\ell=1## piece in the spherical multipole expansion), i.e., the lowest multipole order giving rise to the radiation of electromagnetic waves. It's very easy to see in this Cartesian approach that there is no "monopole radiation" in electromagnetics.
The rest of the calculation is most simply done with starting to calculate the vector potential. The retarded Green's function of the D'Alembert operator is
$$D_{\text{ret}}(t,\vec{r})=\frac{1}{4 \pi r} \delta(t-r/c).$$
Thus the vector potential is
$$\vec{A}_1(t,\vec{r}) = \int_{\mathbb{R}^3} \mathrm{d}^3 r' \frac{\mu_0 \vec{j}_1(t-r'/c,\vec{r'}}{4 \pi |\vec{r}-\vec{r}'|} = -\frac{\mathrm{i} \mu_0 \omega q \vec{d}}{4 \pi r} \exp(\mathrm{i} k r - \mathrm{i} \omega t).$$
From this it's a piece of cake to calculate
$$\vec{B}_1=\vec{\nabla} \times \vec{A}_1.$$
Instead of also calculating ##\Phi_1##, it's easier to use the Maxwell-Ampere equation to directly obtain ##\vec{E}_1##, making use of the fact that the time dependence of all fields is simply a factor ##\exp(-\mathrm{i} \omega t)##:
$$\vec{E}_1=\frac{\mathrm{i} c^2}{\omega} \vec{\nabla} \times \vec{B}_1.$$
No.
Griffiths starts with the static potentials $$V(\vec r) = \frac 1 {4 \pi \varepsilon_0} \int {\frac {\rho ({\vec r}^\prime)} {|\vec r - {\vec r}^\prime|} \, d {\vec \tau}^\prime} \\ \vec A (\vec r) = \frac {\mu_0} {4 \pi} \int {\frac {\vec J ({\vec r}^\prime)} {|\vec r - {\vec r}^\prime|} \, d {\vec \tau}^\prime}$$ He generalizes them by evaluating ##\rho## and ##\vec J## at the retarded time for each source point: $$t_r = t - \frac {|\vec r - {\vec r}^\prime|} c$$ to get $$V({\vec r}, t) = \frac 1 {4 \pi \varepsilon_0} \int {\frac {\rho ({\vec r}^\prime, t_r)} {|\vec r - {\vec r}^\prime|} \, d {\vec \tau}^\prime} \\ \vec A ({\vec r}, t) = \frac {\mu_0} {4 \pi} \int {\frac {\vec J ({\vec r}^\prime, t_r)} {|\vec r - {\vec r}^\prime|} \, d {\vec \tau}^\prime}$$ Then he says:
Griffiths said:
Well, that all sounds reasonable—and surprisingly simple. But are we sure it's right? I didn't actually derive these formulas for ##V## and ##\vec A##; all I did was invoke a heuristic argument ("electromagnetic news travels at the speed of light") to make them seem plausible. To prove them, I must show that they satisfy the inhomogeneous wave equation (10.16) and meet the Lorentz condition (10.12). In case you think I'm being fussy, let me warn you that if you apply the same argument to the fields [##\vec E## and ##\vec B##] you'll get entirely the wrong answer [...]
He then shows that the retarded potentials satisfy (10.16) and leaves it as an exercise to show that they satisfy (10.12).
(Actually he does only the scalar potential explicitly, and says that "essentially the same argument would serve for the vector potential".)
[This is from the 3rd edition. The 4th edition may be different.]
  • · Replies 21 ·
  • · Replies 70 ·
