What is the Electric Field at the Surface of the Wire and Cylinder?
In summary, the conversation is about finding the electric field at the surface of a wire and a cylinder based on given dimensions and applied voltage. The suggested approach is to solve Laplace's equation using cylindrical coordinates, and another possible method involves integrating from the wire's radius to a point of interest.
stunner5000pt
1,461
Absolutely stumped here!
A geiger counter has a metal cylinder of 2.10 dimater with a wire stretched along it's axis whose diamtere is 1.34 x 10^-4 cm in dimater. If 855 V is applied between these two what is the electric field at the surface of the wire and the cylinder??
lets say lambda = Q / L
then flux = EA = E 2 pi r L = 4 pi k Qenc = 4 pi k lambda L
so 2 k lambda / r = E
then i integrate because V = integrate E dr
so that V = 2k lambda Log r
But now i m stumped as to how to proceed please help!
thanks a lot
You might try solving Laplace's equation directly since there is no charge in the space between the wire and the cylinder
[tex]\nabla^2 \phi = 0[/tex]
using cylindrical coordinates and making use of your symmetry approximation. (It's easier than it looks!)
ok thansk a lot BUT I'm not that high in math can u try suggeting a lower math approach?
Sorry about that -
You can do it the way you started but you have to careful when you integrate (i.e. the [itex]\ln r[/itex] makes no sense because it can't contain units!)
What you need to do is to integrate from, say, the radius of the inner wire out to a point of interest. To determine the value of the unknown charge you will need to integrate from the radius of the wire all the way out to the radius of the cylinder in which case the potential difference is known to be 855 Volts.
You will end up with something like
[tex]V(r) = \Delta V \frac {\ln r/r_0}{\ln R/r_0}[/tex]
where [itex]r_0[/itex] is the radius of the wire and [itex]R[/itex] is the radius of the cylinder.
Technically, there is an arbitrary additive constant in there but it doesn't matter where you define the zero of the electrical potential since you're going to calculate the derivative to find the electric field.
1. What is an electric field?
An electric field is the physical quantity that describes the influence of electrically charged objects on each other. It is represented by a vector that points in the direction of the force experienced by a positive charge placed in the field.
2. How is the electric field calculated?
The electric field at a point can be calculated by dividing the electric force acting on a test charge placed at that point by the magnitude of the charge. It can also be calculated by dividing the electric potential difference between two points by the distance between them.
3. What are the units of electric field?
The SI unit of electric field is Newtons per Coulomb (N/C), which can also be written as Volts per meter (V/m). Other commonly used units include kilovolts per meter (kV/m) and megavolts per meter (MV/m).
4. How does the direction of an electric field relate to the direction of the electric force?
The direction of the electric field is always in the direction that a positive test charge would move if placed in the field. The direction of the electric force on a positive charge is in the same direction as the electric field, and in the opposite direction for a negative charge.
5. What are some real-life applications of electric fields?
Electric fields have several practical applications, such as in electronic devices like computers and smartphones, where they are used to control the movement of electrons. They are also used in medical technologies like electrocardiograms and MRI machines. Additionally, electric fields are used in industries like agriculture for pest control and in particle accelerators for scientific research.
