Homework Help: Electric Field in a point
  1. Sep 4, 2007 #1
    I want to find an electric field in a point (x,y,z) generated by 2 charges:
    q1 = q, and q2=2q, q1’s position = (1,2,3) and q2’s position = (4,5,6),
    I tried to solve it by using superposition principle, adding the E of each charge to point x,y,z, I am doing something wrong probably with vectors calculation.
    Please explain.
  3. Sep 4, 2007 #2
    G01
    Where in the calculation are you getting stuck? I'm not going to be able to give you any decent help if you don't show some work.
  4. Sep 4, 2007 #3
    well,
    E = 1/[4*Pi*epsilon0] * (q/r1^2 * r1 + q/r2^2 * r2)
    r1 and r2 vectors
  5. Sep 4, 2007 #4
    r1=(x-1,y-2,z-3)
    r2=(x-4,y-5,z-6)
    after that and calculating all constants i get stuck.
  6. Sep 4, 2007 #5
    learningphysics
    The vectors should be unit vectors...
  7. Sep 4, 2007 #6
    yes unit vector,
    I get: r1/|r1| but this doesn’t give me anything
  8. Sep 4, 2007 #7
    If it should be like this:
    E[x] = E1*(1/sqrt(14),0,0)+E2..
    Thanks.
  9. Sep 4, 2007 #8
    learningphysics
    Yeah, how is the answer supposed to look? How do you know your answer is wrong?
  10. Sep 4, 2007 #9
    I don't know the answer, but my answer has form with a lot of x,y and z variables.
  11. Sep 4, 2007 #10
    learningphysics
    There should be 2q in the numerator or r2^2.
  12. Sep 4, 2007 #11
    well,
    E = 1/[4*Pi*epsilon0] * (q/r1^2 * r1/|r1| + q/r2^2 * r2/|r2|)
    r1 and r2 vectors
    did you solve this one?
    You would get lots of x,y,z vars, if you do
    yea, changing to q2=2q should give the answer..
  13. Sep 4, 2007 #12
    Yes, 2q.
    I have a follow up question, to find field in (10,10,10) where q1=10^-6 q2=2*10^-6
    and the answer for that is 10^-9K(21.09x’+17.76y’+14.43z’)
    My answer and the point (10,10,10) doesn’t give this result.
  14. Sep 4, 2007 #13
    rootX,
    yes I get a mess of x,y and z.
  15. Sep 4, 2007 #14
    I am doing something wrong with vectors, it's shouldn't be complicated...
  16. Sep 4, 2007 #15
    learningphysics
    Just leave it as the sum of the two fields... also you can factor out [tex]\frac{q}{({r_1^2})^{3/2}}[/tex] for the first part... and [tex]\frac{q}{({r_2^2})^{3/2}}[/tex] for the second part...
    so all the messy stuff in the denominator can get factored out of the vectors... don't actually multiply out (x-a)^2 + (y-b)^2.... etc.
  17. Sep 4, 2007 #16
    I get
    kq (0.123,1.17798..)
    I guess I also messed up something..
  18. Sep 4, 2007 #17
    ok, I am 55% sure that this answer is wrong: 10^-9K(21.09x’+17.76y’+14.43z’)
    here's what I got from maxima:
    kq(0.14227258171877 , 0.20662308551546 , 0.270973589312)
  19. Sep 4, 2007 #18
    learningphysics
    I'm getting the answer that is given: 10^-9K(21.09x’+17.76y’+14.43z’)
  20. Sep 4, 2007 #19
    learningphysics,
    can you please give your solution?
  21. Sep 4, 2007 #20
    learningphysics
    Basically I got:
    [tex]kq*[\frac{(9,8,7)}{{194}^{3/2}} + 2*\frac{(6,5,4)}{{77}^{3/2}}][/tex]
    this evaluates to the given answer.
  22. Sep 4, 2007 #21
    lol
    I was doing [sqrt(194)]^3/2 and [sqrt(77)]^3/2
    Thanks
  23. Sep 4, 2007 #22
    and I was using (1,2,3) for (9,8,4) and (4,5,6) for..
  24. Sep 5, 2007 #23
    Another related question:
    There are 2 linear charges distributed on y and x axis, segments lengths 0<=x<=l and 0<=y<=l.
    Density of the charges is not uniformed: gamma(x)=bx and gamma(y)=by.
    Need to fine E(0,0,z)
    I tried to do following:
    Because those 2 segments lay on axis x and axis y the needed Electric field is on axis z.
    And because of symmetric I can calculate the contribution of one segments and contribution of the second will be the same.
    So I need to find dE and then dE_z.
    dE= [tex]\frac{kdq}{r^2}[/tex]
    dE_z= [tex]\frac{kdq}{r^2}[/tex] sin ([tex]\alpha[/tex])
    r^2 = [tex]\sqrt{z^2+l^2}[/tex]
    Am I doing right so far?
  25. Sep 5, 2007 #24
    learningphysics
    You meant:
    [tex]r=\sqrt{z^2+l^2}[/tex]
    Yes, what you've described will give you the field for one segment at the point z along the z-axis... then you can double it to get the field along the z-axis...
    But you also need another component of the field at (0,0,z)
  26. Sep 5, 2007 #25
    What do you mean by another component?
Loading...
