1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
Electric Field Lines
  1. Feb 2, 2013 #1
    A uniform electric field of magnitude 6.5 [itex]\frac{N}{C}[/itex] passes through a circle of radius 12 cm. What is the electric flux through the circle when its face is perpendicular to the field lines.
    3. The attempt at a solution
    The only problem with this question is picturing the field lines. I initially thought that "perpendicular" meant 90°.
    I tried to apply that angle to the flux formula, but I need to picture this surface? I'd appreciate an explanation of the EF and field lines. Or if there is a website that I can check that explains and shows how electric fields and field lines are shown.
  3. Feb 2, 2013 #2
    Dick
    The surface is a disk. And yes, perpendicular means 90 degrees. The E field is normal to the surface. What's the definition of 'flux'? You should be able to look that up. There aren't very many easier flux questions around.
Similar Discussions: Electric Field Lines
Loading...
