Electric Field Lines: Does Positive Test Charge Follow?
In summary, a positive test charge will follow the path of electric field lines if it is free to do so, as it feels a force due to the field vector at each point. However, the field lines are not necessarily straight, so the trajectory of the charge may not be either. In the example of a parallel plate capacitor, the field lines are perpendicular to the plates and the field strength is constant, resulting in a parabolic path for a charged particle with an initial velocity parallel to the plates.
Mausam
27
Does a positive test charge follows along the path of electric field lines if it is free to do so? I mean the trajectory of the charge is along the electric field lines and the field lines are not necessarily straight.
No. The positive test charge feels a force due to the field vector at that point. The charge's position gets updated and then feels another force at the new point, and so on.
Example... given a parallel plate capacitor, the field lines between the plates are perpendicular to the plates and the field strength is constant.
If a charged particle between the plates has a velocity initially parallel to the plate, that particle will follow a parabolic path.
Likes conscience, cnh1995 and hsdrop
1. What are electric field lines?
Electric field lines are a visual representation of the direction and strength of an electric field at different points in space. They are imaginary lines that show the path a positive test charge would take if placed in the electric field.
2. How are electric field lines drawn?
Electric field lines are drawn by placing a positive test charge at different points in the electric field and then drawing lines in the direction of the force that the charge would experience at that point. The closer the lines are together, the stronger the electric field is at that point.
3. What do electric field lines look like for a positive point charge?
For a positive point charge, electric field lines radiate outwards in all directions, with the highest concentration of lines near the charge. This represents the strong electric field that is created by a positive charge.
4. Do electric field lines always have to start and end on charges?
No, electric field lines do not always start and end on charges. In the case of a uniform electric field, the lines will be parallel and evenly spaced, with no starting or ending points. However, for a non-uniform electric field, the lines will start and end on charges.
5. How do electric field lines show the strength of an electric field?
The density of electric field lines is a visual representation of the strength of the electric field. The closer the lines are together, the stronger the electric field is at that point. Similarly, the further apart the lines are, the weaker the electric field is at that point.
  • Electromagnetism
  • Electromagnetism
