Homework Help: Electric Field Of A Cable
  1. Feb 18, 2014 #1
    Kot
    A long coaxial cable of length L consists of a cylindrical metal sheath of radius b surrounding a conducting wire with outer radius a. The sheath and wire are given the same charge per length +Q/L. Find the electric field in terms of distance r from the central axis of the wire in the regions 0 < r < a, a < r < b, and r > b.
    2. Relevant equations
    Gauss' Law ∫EdA = Qino
    3. The attempt at a solution
    I am not really sure how to do this problem but I think I have an idea. I have to find the electric field in terms of distance r of three different regions 0 < r < a, a < r < b, and r > b. Since the cable and metal sheath have the same charge per length, wouldn't they both have the same charge and cancel out? Could someone explain how I can find the Gaussian surface for the first region?
  3. Feb 18, 2014 #2
    tiny-tim
    Hi Kot! :smile:
    For r > b, yes
    So the electric field there is … ? :wink:
    (for r < a) Why don't you just use a cylinder of radius r ?
  4. Feb 18, 2014 #3
    Kot
    For r > b, the electric field wouldn't completely cancel out since I was given an arbitrary a and b.
    For a < r < b, I am still not sure what radius to use. How can i express a radius that is between a and b?
  5. Feb 18, 2014 #4
    tiny-tim
    Hi Kot! :smile:
    But the question says that the charges per length are equal. :confused:
    Just call it r.
    What do you get?​
  6. Feb 18, 2014 #5
    Kot
    It's charge per length is equal but doesn't the length of a and b also contribute to the electric field?
    For a < r < b, if I have a Guassian surface (cylinder in this case) then I get:
    EA = ρV / εo
    E2∏rL = ρ∏r2L / εo
    E = ρ / 2 εo
  7. Feb 18, 2014 #6
    tiny-tim
    charge per length is what it says
    the radius (a or b) has nothing to do with it
    what is ρ ? :confused:
    you seem to be calculating a volume
    the charge is a surface charge, on two cylindrical shells
  8. Feb 18, 2014 #7
    Kot
    Oops,
    EA = σA / εo
    E(2∏rL) = σ(2∏rL) / εo
    E = σ / εo
    where σ is the surface charge density of the cylinders. Is this correct?
  9. Feb 18, 2014 #8
    tiny-tim
    what is this supposed to be? :confused:
    (and what does 2πr have to do with it?)
  10. Feb 18, 2014 #9
    Kot
    σ(2∏rL) is σA, the surface charge density of the cylinder. Since I need to find the electric field, I used Gauss' Law ∫EdA = Qenclosed / εo . I replaced Qenclosed with σA.
  11. Feb 18, 2014 #10
    tiny-tim
    But the surface charge depends only on L :redface:
    (and now i'm off to bed :zzz:)
  12. Feb 18, 2014 #11
    Kot
    Could I get a hint on how to do this problem?
  13. Feb 19, 2014 #12
    tiny-tim
    (just got up :zzz:)
    If …
    … then what is the total charge inside a cylinder of length L and radius r (a < r < b) ?
  14. Feb 19, 2014 #13
    Kot
    Would the total charge inside a cylinder be Qenclosed = E2∏rLεo ?
  15. Feb 19, 2014 #14
    tiny-tim
    why?? :confused:
    (and what is E ? and what happened to Q ?)
  16. Feb 19, 2014 #15
    Kot
    I used Gauss's Law. The E is the electric field and Q is the total charge enclosed inside the cylinder.
  17. Feb 19, 2014 #16
    rude man
    Start by setting up a Gaussian surface inside the inner wire ( r < a). What is the shape of the surface?
  18. Feb 19, 2014 #17
    Kot
    The Guassian surface is a cylinder. Since it is symmetrical I don't have to do the integral, I can use EA = Qenclosed / εo. The area of the cylinder would be 2∏rL.
  19. Feb 19, 2014 #18
    rude man
    Right. But what is Qenclosed?
  20. Feb 19, 2014 #19
    Kot
    If I let the Guassian surface (cylinder) to be the same length as the cable, Qenclosed would be the same length as the cable L. I can rewrite Q as λL. Is that right?
  21. Feb 19, 2014 #20
    rude man
    Well, where do you think the charges are located on the inner wire?
  22. Feb 19, 2014 #21
    rude man
    Remember, the cable's inner and outer conductors are just that - conductors.
  23. Feb 19, 2014 #22
    Kot
    Since it is a conductor, wouldn't the electric field be zero?
  24. Feb 19, 2014 #23
    rude man
    Yes, but my question was, where are the charges located? The problem said you have Q coulombs per meter charge sitting somewhere in/on the inside wire.
  25. Feb 19, 2014 #24
    Kot
    The charges are located at the center of the Guassian cylinder.
  26. Feb 19, 2014 #25
    rude man
    No. The charges all repel each other & so want to get as far away from each other as possible. So where would that be?
Have something to add?
Draft saved Draft deleted
