Electric Field of a Square
  • Thread starter bpichich
bpichich
1. The problem
There are four charges at the corners of a square of side L. Three of the charges are -q and one is
-Q(upper left corner).
A) Find the force on -Q, assuming -Q< 0.
B) If -Q=-q, find the electric field at the center of the square.
Coulomb's Law
E = k (Q1)(Q2)/r2
E = E1 + E2 + ...
3. The attempt
A) I basically did E = k [(2q)(-Q)/ (L)2 + (q)(-Q)/(2L2)^1/4] or something like that on the test. In my textbook it says to use the superposition principle, when there's multiple charges.
Answers and Replies
Simon Bridge
17,874
1,657
hint: electric field is a vector
kosovo dave
Here's how I'd do it (not the quickest way, but by doing it this way you can make your own shortcuts later on).
a) using F=kq1q2/r^2, find the force btwn -Q and -q1, -Q and -q2, -Q and -q3. Add these up. This will be the net force at the point you interested in.
b) pretend that you put a positive point charge +q at the center of the square. Ignoring the influence of any of the three corners, which way will the test charge move? This will be the direction of the electric field due to your given source charge. do this for each corner. do any of the vectors look like they cancel? if you can't tell right away, try breaking each vector up into x and y components and seeing if they add/subtract/cancel.
Simon Bridge
17,874
1,657
This is what OP did. However, you left out that it has to be a vector sum.
Suggested for: Electric Field of a Square
  • Last Post
15K
  • Last Post
22K
22K
  • Last Post
  • Last Post
10K
