Electric Field of a Uniformly Charged Ring: Finding Emax Along the Axis
E = C*x/(x^2 + a^2)3/2 and it can be simplified to E = C*x/(a^2 + x^2)2 Then you can use the quotient rule again to differentiate E with respect to x, and then set that to 0 to find the maximum value for E.
physics_geek
84
Determine both the location and the maximum magnitude Emax of the electric field along the axis of a uniformly charged ring. (Use epsilon_0 for ε0, Q, and a as necessary.)
dE= k_edq/r^2costheta
costheta= x/r
i think i have to take the derivative of some forumla
that looks like this:
(kex)/(a^2 + x^2)^3/2 all multiplied by Q
and set this to zero and find a max
i really have no idea how to do this
costheta= x/r
That looks about right.
http://hyperphysics.phy-astr.gsu.edu/hbase/electric/elelin.html#c2
Maybe take the differential using the quotient rule?
(d(f(x)/g(x))/dx = ( f '(x)g(x) - f(x)g '(x) ) / g2(x)
yes i applied the quotient rule
but it gets extremely confusing..i end up with an answer like (a+x)(a+x) =0
which I am pretty sure is incorrect
I didn't work it out, but I noticed that the divisor goes away when you set it to 0, leaving you just
( f '(x)g(x) - f(x)g '(x) ) = 0
or when f '(x)g(x) = f(x)g '(x)
so that would leave us with
3a+3x(a^2+x^2)^3/2(kex) - ke(a^2+x^2)^3/2 = 0
wat abt the Q in the original equation
im not very good at calculus so this is pretty tough for me
Going by the link:
That gives you the equation to begin with and basically there's all the constants invariant in x, so Q just gets carried along through as part of that constant. Let's call it C.
E = C*x/(x2 + a2)3/2
Since it seems to be a common factor I don't think it affects Xmax as it looks to cancel out when you set it to 0.
(Of course it does matter in evaluating |E|.)
Using the quotient rule where f(x) = C * x, and g(x) = (x2 + a2)3/2
So doesn't it look like (using the chain rule to determine g'(x)) and then setting to 0 that :
C*(a2 + x2)3/2 = 3*C*x2(a2 + x2)1/2 ?
If that's right then it looks like it simplifies to
3x2 = (a2 + x2)
or
x = (a*√2)/2 ?
Not sure if it's right, but it feels right. No time to double check it. You certainly should.
you are a genius!
thanks for clearing that up
but now using the x value how do i find Emax?
physics_geek said:
you are a genius!
By substitution into your original equation, now that you know x in terms of a.
1. What is the formula for the electric field of a ring?
The formula for the electric field of a ring is E = kQz/(z2 + R2)3/2, where k is the Coulomb constant, Q is the charge of the ring, z is the distance from the center of the ring, and R is the radius of the ring.
2. How does the electric field of a ring differ from that of a point charge?
The electric field of a ring differs from that of a point charge in that it is not constant at all points in space. The electric field strength at a point on the axis of a ring is directly proportional to the distance from the center of the ring, whereas the electric field of a point charge is inversely proportional to the square of the distance from the point charge.
3. Does the electric field of a ring have any directionality?
Yes, the electric field of a ring has directionality. The direction of the electric field at any point on the axis of the ring is perpendicular to the plane of the ring and points either towards or away from the ring depending on the direction of the charge.
4. Can the electric field of a ring be negative?
Yes, the electric field of a ring can be negative. This occurs when the charge on the ring is negative. The negative sign in the formula for the electric field of a ring indicates the direction of the electric field is opposite that of a positive charge.
5. How does the electric field of a ring change as the distance from the ring increases?
The electric field of a ring decreases as the distance from the ring increases. This is because the electric field strength is inversely proportional to the cube of the distance from the center of the ring. As the distance increases, the denominator in the formula becomes larger, causing the electric field strength to decrease.
