Homework Help: Electric field over a non-conducting disk in term of ε0
  1. Oct 4, 2012 #1
    A non-conducting disk with a 4-mm thickness is lying flat. It has a -4 C/m^2 surface charge on the upper surface and a surface charge on the lower surface. In terms of epsilon naught, what is the approximate field strength 1 mm above the upper surface?
    2. Relevant equations
    E(disk)z = η/2ε0 * [1- ( z /√(z^2 +R^2)) ]
    3. The attempt at a solution
    The radius R and charge are unknowns, I have no idea how to aproach this problem, Im stuck. I would like some help to interpret the known data so I can start to build an answer! Please, and thanks in advance for any suggestions.
Draft saved Draft deleted
