Homework Help: Electric field problem
  1. May 4, 2013 #1
    An electron is accelerated from rest across a set of parallel plates that have a potential difference of 150V and are separated by 0.80 cm.
    a) Determine the kinetic energy of the electron after it crosses the plates
    2. Relevant equations
    N/C = J/C/d
    3. The attempt at a solution
    +++++++++++++++++ delta => {(150 V), (0.8 cm)}
    e (going up)
    150 J/C / (0.8 cm * 1 m / 100 cm) = 18750 N/C
    So at the start it has about 18750 N/C * e of potential energy, all which transfers to kinetic energy at the end, meaning it has 18750 N/C * e of kinetic energy at the end point
    18750 N/C * 1.6 * 10^-19 C
    and I get an answer of 3e-15 J.
    However, the book lists 2.4 * 10^-17 J. What did I do wrong?
  3. May 4, 2013 #2
    SammyS
    Staff Emeritus
    That should be N/C = J/C/m
    A quantity with units of N/C time a quantity with units of charge, gives a quantity with units of N, i.e. a Force, not energy.
  4. May 4, 2013 #3
    Thank you for your help. I can't believe I didn't notice that. I guess it's time for a break! :P
  5. May 4, 2013 #4
    SammyS
    Staff Emeritus
    Yes.
    An object of charge, Q, when accelerated through a potential difference of X Volts, will gain (Q times X) Joules of Kinetic Energy.
Have something to add?
Draft saved Draft deleted
Loading...
