Electric field problems
  • Thread starter kmjones26
I need help getting started on a few questions. If you could just provide the equation I should use then I would be very thankful.
1. A point charge of 2Q is a distance L from a point charge of -Q. What is the electric field at Point P a distance L abouve the center of the 2 charges. Picture below:
<...........>P
2Q______L______-Q
2. What would the force be on a -Q charge placed at the point a distance L above the center of the charges in the problem above.
3. What is the electric field a distance of 0.5 meters above an infinite plain of charge density 25C/m^2
4. If the center of a flat plate wish a radius of 5cm is placed at an angle of π /3 radians, 1 meter above the infinite plain from the previous problem, then what would be the flux through the plate?
5. What would be the electric field a distance R away from an infinite wire with a charge density of λ
Answers and Replies
tiny-tim
25,836
251
Welcome to PF!
Hi kmjones26! Welcome to PF! :smile:
(try using the X2 tag just above the Reply box :wink:)
1. Electric field is a vector, so find the two vectors at P from the two charges, and add the components.
2. Force = charge times electric field (F = qE). :wink:
Show us what you get. :smile:
Related Threads on Electric field problems
  • Last Post
  • Last Post
9K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
