Electric Field Behavior Between Charged Parallel Plates
In summary, the conversation discusses the behavior of electric fields between two parallel plates with uniform positive charge density. It is noted that in an ideal situation with infinite plates, the electric field and force do not vary with distance from the plate. However, near the edges of the plates, the electric field pushes a positive charge out of the interval.
Arup Biswas
34
One side of a plate has a uniform positive charge density. Two of those plates are placed parallel to each other in a distance away, with their charged side facing each other! The electric field between is zero then! If we put a charge there it will feel no force? I think if the charge is put anywhere between the plates except the middle point, then the plate nearer to it will exert more force on it, and try to pull back it to the centre! That is the no field reigion is a point only ? (Sorry for not explaining that much)
If the plates are not infinite then?
Hi. Near edges of the plates electric field push a positive charge out of the interval.
What is an electric field?
An electric field is a physical field that surrounds electrically charged particles and exerts a force on other charged particles within its range. It is represented by lines of force, which show the direction and strength of the force at any given point.
How is an electric field created?
An electric field is created by electrically charged particles, such as electrons and protons. When these charged particles are not in motion, they create an electric field that permeates the space around them. If the charged particles are in motion, their electric field can also change over time.
Can an electric field exist without a charge?
No, an electric field cannot exist without a charge. The presence of a charge is necessary for the creation and existence of an electric field. The magnitude and direction of the electric field are dependent on the charge causing it.
How do you measure an electric field?
Electric fields can be measured using a device called an electric field meter or by using mathematical equations that take into account the properties of the charged particles creating the field. The unit for measuring electric field strength is volts per meter (V/m).
What are some real-world applications of electric fields?
Electric fields have a wide range of applications in our daily lives. They are used in electronic devices, such as computers and smartphones, as well as in medical equipment like MRI machines. Electric fields are also used in power generation and transmission, as well as in industrial processes like electroplating. Additionally, electric fields play a crucial role in lightning and the Earth's atmospheric processes.
  • Electromagnetism
  • Electromagnetism
17K
