Calculating Electric Field Strength from Kinetic Energy and Displacement
In summary, the conversation is about a particle with a charge of 4.4nC in a uniform electric field, which is released from rest and moves to the left. After moving 6.00 cm, its kinetic energy is found to be 3E-6 Joules. The conversation includes questions about the work done by the electric force, the potential of the starting point with respect to the endpoint, and the magnitude of the electric field. The answers to these questions are 0.000003 J, 681.818 V, and E=V/d, where V is the potential difference across a distance d.
eku_girl83
89
Here's the problem:
A particle with a charge of 4.4nC is in a uniform electric field E directed to the left. It is released from rest and moves to the left. After it has moved 6.00 cm, its kinetic energy is found to be 3E-6 Joules.
a) What work was done by the electric force?
.000003 J
b) What is the potential of the starting oint with respect to the endpoint?
681.818 J
I got these parts correct, but am having trouble with part c.
c) What is the magnitude of E?
Could someone give me a hint?? Thanks!
.000003 J
OK
681.818 J
That's 681 Volts, not Joules.
Do you know that E=V/d for a uniform E-field where V is the potential difference across a distance d?
To calculate the magnitude of the electric field, you can use the equation E = F/q, where F is the force exerted by the electric field and q is the charge of the particle. In this case, the force is equal to the work done (as calculated in part a) divided by the displacement of the particle (6.00 cm or 0.06 m). So, the equation becomes E = W/d, where W is the work done and d is the displacement.
Substituting the values, we get E = (0.000003 J)/0.06 m = 0.00005 N/C. Therefore, the magnitude of the electric field is 0.00005 N/C.
Another way to approach this problem is by using the equation for kinetic energy, KE = 1/2 mv^2, where m is the mass of the particle and v is its velocity. Since the particle is released from rest, its initial velocity is 0 m/s. So, the equation becomes KE = 1/2 mv^2 = 1/2 m(0.06 m/s)^2 = 3E-6 J.
We know the charge of the particle (4.4nC) and we can calculate the mass using the equation for electric force, F = qE = ma, where a is the acceleration of the particle. In this case, the acceleration is equal to the change in velocity divided by the displacement, which is 0.06 m/s divided by 0.06 m, giving us an acceleration of 1 m/s^2. So, the equation becomes F = qE = ma = m(1 m/s^2), and solving for m, we get m = 4.4E-9 kg.
Now, we can substitute the values for m and KE into the equation KE = 1/2 mv^2 and solve for v. This gives us v = 0.06 m/s.
Finally, we can use the equation for electric field, E = F/q, where F is equal to the mass of the particle (4.4E-9 kg) multiplied by its acceleration (1 m/s^2). So, E = (4.4E-9 kg)(1 m/s^2)/(4.4E-9 C) = 1 N/C. Therefore, the magnitude of the electric field is 1 N/C
1. How is electric field strength related to kinetic energy and displacement?
Electric field strength is directly proportional to both kinetic energy and displacement. This means that as the kinetic energy or displacement increases, the electric field strength also increases.
2. Can electric field strength be calculated from kinetic energy and displacement?
Yes, electric field strength can be calculated using the formula E = KQ / r^2, where E is the electric field strength, K is the Coulomb's constant, Q is the charge, and r is the distance between the charge and the point where the electric field is being measured.
3. How does displacement affect the electric field strength?
Displacement affects the electric field strength by increasing or decreasing the distance between the charge and the point where the electric field is being measured. The farther the distance, the weaker the electric field strength will be.
4. What units are used to measure electric field strength?
Electric field strength is measured in Newtons per Coulomb (N/C) or Volts per meter (V/m).
5. Can electric field strength be negative?
Yes, electric field strength can be negative. A negative electric field strength indicates that the field is directed in the opposite direction of the electric force, which is typically towards the negative charge.
