Electric field
  • Thread starter robert25pl
Given E in a region of space ( [tex]\epsilon_{o} , \mu_{o}[/tex])
I should think of it as a free space or vacuum?
Answers and Replies
This is vacuum.
I have to find [tex]B[/tex], [tex]\rho[/tex] and [tex]J[/tex]
[tex] \nabla \times \vec E= -\frac{\partial \vec B}{\partial t} [/tex]
[tex] \nabla \cdot D=\rho [/tex]
In free space J = 0 so for J in vacuum I should use
[tex] \nabla \times H =J+ \frac{\partial D}{\partial t}[/tex]
or something else?
OlderDan
3,021
or something else?
You probably want to use
[tex]D = \epsilon_{o} E [/tex]
[tex]B = \mu_{o} H, [/tex]
to eliminate D and H. Don't know if you will need it, but you can round out your set of equations with
[tex] \nabla \cdot B=0 [/tex]
I think I got B, D, H and [tex] \rho[/tex] and using
I get J
What is the difference between free space (J = 0) and vacuum?
dextercioby
Insights Author
13,147
708
Vacuum means [itex] \mu_{0},\epsilon_{0} [/itex].If you're speaking about "free space",then u should assume no charge density [itex] \rho=0 [/itex] and no charge transport [itex] \vec{J}=0 [/itex].
So we can have sources in vacuum.But not in free space.
Free space is typically a vacuum in which electromagetic waves (radiation far away from the sources) propagate.
Daniel.
Thanks, So in my problem I will get J not equal 0
dextercioby
Insights Author
13,147
708
Please post the text of your problem in its exact form.
Daniel.
In the region of space [tex]\epsilon_{o} , \mu_{o}[/tex]
[tex]E = (6z\vec{i}+10y\vec{j})cos500t \vec{j}[/tex]
Find [tex]B, \rho, J[/tex]
dextercioby
Insights Author
13,147
708
[tex] \nabla\cdot\vec{E}=\frac{\rho}{\epsilon_{0}} [/tex] (1)
[tex] \nabla\times\vec{E}=-\frac{\partial\vec{B}}{\partial t} [/tex] (2)
[tex] \nabla\times\vec{B}=\mu_{0}\vec{J}+\mu_{0}\epsilon_{0}\frac{\partial\vec{E}}{\partial t} [/tex] (3)
Daniel.
Related Threads on Electric field
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
J
