Calculating Electric Field Between Charged Particles
In summary, to find the magnitude and direction of the electric field at the midpoint between a -8.0 microcoulomb and a 7.0 microcoulomb charge 8.0 cm apart, we use the formula E=F/q along with Coulomb's law to calculate the individual fields at the midpoint due to each charge. Adding these fields together, we get a net electric field of 4.92 x 10^20 N/C directed away from the -8.0 microcoulomb charge. It is important to note that the test charge used in the calculation of the electric field cancels out in practical situations.
jena
74
Hi,
My Question:
What are the magnitude and direction of the electric field at a midway between a -8.0 microcolumb and a 7.0 microcolumb charge 8.0 cm apart? Assume no other charges are nearby.
Work
[tex]E=F/q[/tex]
[tex]F=(kQ1Q2)/r^2[/tex]
F=((9.0 X 10^9 N m^2/C)(-8.0 X10^-16 C)(7.0 X10^-6C))/(.08m)^2
F=-78.75 or 78.75 N
E=(78.75N)/(1.6X10^-19C)
E=4.92 x 10^20 N/C
Is this correct or should I look at findin the electric field using Q1 and Q2 seperately then adding them together to find a net elecrical field.
Thank you :smile:
You need to find the field at the midpoint due to each charge, then add those fields. Don't forget: Direction matters.
In E=F/q , the q has to be the same *test charge* that the Force acts on!
That is, in all practical situations, the test charge q cancels.
The part of the E-field at test location t, contributed by charge Q1, is
E_1t = k Q1/(r_1t)^2 (away),
where r_1t = distance from Q1 to the test location (.04m in your case).
Oh... okay thanks :smile:
1. How do I calculate the electric field between two charged particles?
To calculate the electric field between two charged particles, you will need to use the equation E = kQ/r^2, where k is the Coulomb's constant (8.99 x 10^9 Nm^2/C^2), Q is the magnitude of the charge of the particle, and r is the distance between the two particles. This equation assumes that the particles are point charges and there are no other charges present.
2. What units are used to measure electric field?
The SI unit for electric field is Newtons per Coulomb (N/C). However, it can also be expressed in Volts per meter (V/m). Both units represent the force per unit charge experienced by a particle in an electric field.
3. Can the electric field between two charged particles be negative?
Yes, the electric field between two charged particles can be negative. A negative electric field indicates that the force would be directed in the opposite direction of the field. This can happen if the charges are of opposite signs and attract each other.
4. How does the distance between charged particles affect the electric field?
The electric field between two charged particles is inversely proportional to the square of the distance between them. This means that as the distance between the particles increases, the electric field decreases. Conversely, as the distance between the particles decreases, the electric field increases.
5. Can the electric field between charged particles be zero?
Yes, the electric field between two charged particles can be zero. This would happen if the charges are of equal magnitude and opposite signs, canceling out the electric field between them. Additionally, if the distance between the particles is infinite, the electric field would also be zero.
