Electric flux
590
given a cube,each side with a lenth of A, placed at with its back left hand bottom corner at (0,0,0).
find the electric flux passing through the sides if the electric field is
a) E=(-3x)i + (2y)j + (4z)k
b) E=(sin(pi*x/A)i + cos(pi*y/2A)j
for a) since the area of each side is A2, flux=A2*E, since the cube is at the origin, anything on -x,-y,-z will have o value (for x,y,z) and therfore 0 E and so 0 flux
flux=
flux from
right= 2*A*A2 =2A3
left= 2*0*A2 =0
top= 4*A*A2 = 4A3
bottom= 4*0*A2 =0
front= -3*A*A2=-3A3
back= -3*A*A2 =0
for b) i cant see how they got the answers, the answers are all 0 other than ffor the left which they say is
left=-A2
but as far as i can tell, the left flux is [cos(pi*y/2A)j * A2 ] cos(pi/2)=0 so i dont see how they come to this??
hope i am doing this right, really not sure, any help appreciated
LowlyPion
3,055
Not so fast. The E field is a vector field and you need to consider the flux passing through the surface.
Φ = ∫ E*dA = ∫ ECosθdA = EA*Cosθ
Now on each of the three faces from the origin the flux will lie in the plane and hence will have 0 contribution, since cos90 =0.
(θ is angle taken with the ⊥ )
But at each of the 3 faces at x,y,z from the origin what will the flux be over the area?
590
dont reallyunderstand, could you pls try pput it into simpler terms, i dont study in english and dont understand what you mean by flux over the area?? where have i gone wrong? i realise that E is a vector
590
but this E has x y and z coordinates
LowlyPion
3,055
Maybe you have the solution, and I have missed your statement?
If your answer is the sum of the fluxes that you found through the 3 outer faces 2A3, 4A3, -3A3, then that looks correct. I didn't understand from your solution if this is what you were saying at first.
LowlyPion
3,055
left=-A2
Evaluating b) you have 0 through x-y faces because there is no z component.
In the z-y, the x components evaluated at x=0 and x=A yield again 0 since sin(π ) = 0
However for the z-x planes evaluated at y=0 and y=A, yields 0 for the Y=A (since cos(π/2) = 0), but cos(0) is 1 so that face will yield a flux over the area A2.
590
i dont understand your workings? could you try step by step please.
for b) why do you evaluate at y=0 and y=A, why is y=0 an option? is this the left hand side of the cube, which is at the origin?? also why is the flux -A^2? when cos0=1 and not -1
590
i think i got it, since the vector of the field goes like j, (in direction of y+), the flux on the left side is -A^2, (since it goes into the left side and not away from it).
since the normal to the side is going to y- and E is going to y+ so cos180=-1,
is this right??
LowlyPion
3,055
Yes. It is the left handed side along the origin, and since it is negative directed (into the surface) the flux is -A2
but howcome for the answer to a), i got the minus from the equation, but here i had to use my logic, surely there must be some rule to follow?
LowlyPion
3,055
In a) you weren't dealing with the complicating factor that you had a negative facing surface with the vector inwardly directed as in the fact that the field vector was positively directed, but inwardly as far as the Gaussian surface was concerned. Those faces had 0 flux crossing the face.
The rule is flux out is positive. Hence for a point charge and a sphere you have outward vectors (positive charge) over all the surface in all directions, and the integral over the surface area accumulates all those positive field vectors to determine the positive charge inside.
But in 2) here you had a surface that, while it had a positive field vector across the face, was not positive with respect to its direction crossing the face.
The Physics Forums Way
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
