Electric flux
  • Thread starter tuggler
A closed cylinder consists of two circular end caps and a curved side. A negatively charged particle is placed outside the left end of the cylinder, on its axis. Compare the flux through the left end of the cylinder with that through the right.
2. The attempt at a solution
I know the field points out of the cylinder on the left end, and into the cylinder on the right, so the flux through the left end is positive while that through the right end is negative. But what above the sides of the curves?
Answers and Replies
Simon Bridge
17,874
1,657
Does the question ask you about the curved sides?
What law tells you how the electric flux from a point charge, through a fixed area, changes with distance?
rude man
Insights Author
856
Let
charge located at x = 0
near end locared at x = d
length of cylinder = L
R = radius of ends
1. Compute the flux through a differential annulus for the near end. Integrate from r = 0 to r = R parametrically using θ = arc tan r/d.
2. Do the same for the far end. Realize θ will range from 0 to a smaller number than for the near end.
3. Compare.
Thanks !
Related Threads on Electric flux
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
