Electric force question
  • Thread starter Brothas
Brothas
First of all, hey everyone.
I was wondering if any of you could help me solve this. I've tried but i keep getting insane equations so I might be doing something wrong.
Two equal spheres with a mass of m have equal charges q. They're suspended by two ropes with length L in points distanced d apart. Calculate the distance between the (centers) of the two spheres when this setup is in balance.
Picture: https://dl.dropbox.com/u/29642931/phys.png [Broken]
What I've tried so far is:
The forces acting on the ball are the electric forces from the charges, the gravity and the tension frmo the rope. I figured the sum of these forces should be 0 for this setup to be balanced, which led me to: Fg + Fel+Frope with |Frope| = |Fg|/cos(θ) + |Fel|/sin(θ), but this is insanely hard to solve..
Answers and Replies
Doc Al
Mentor
45,412
1,850
Good.
I don't understand that last equation. What's the direction of the electric force?
Brothas
The charges are equal, so the electrical forces act 'outwards', right?
I got that last equation by fiddling a bit, I'm not too sure how to find the rope tension force..
kushan
256
use the diagram to find the forces at equillibrium
Doc Al
Mentor
45,412
1,850
Right, which is horizontal.
Redo it by considering horizontal and vertical components separately.
Brothas
Using this diagram, I get the conditions:
|Fel|= q²/(4π*ε*r²) = |T|sin(θ)
|Fg| = mg = |T|cos(θ)
And I'm stuck here: how do I find r (or θ?) from this?
Edit : Dividing top by bottom I get : tanθ = q²/(4π*ε*r²*m*g)
I can write r = d + 2Lsin(θ) -> r² = d²+4dLsinθ + 4L²sin²(θ)
If I denote q²/(4π*ε*m*g) = C (for my ease of writing mainly), I get:
C*cotθ = d²+4dLsinθ + 4L²sin²(θ), which I can then solve for θ (somehow)?
kushan
256
you can try to eliminate T , so that you are left with only one variable (θ)
Doc Al
Mentor
45,412
1,850
I assume you are given θ and L, and must solve for d in terms of θ and L.
Brothas
What I assume is L,d,q and m are given. (d being the distance between the fixpoints of the two ropes). I then have to solve for the distance r between the centers of the spheres (which can be found by finding θ.)
Doc Al
Mentor
45,412
1,850
Ah, OK. Do you need to solve it analytically, or are you given values for those givens? (Which you can then plug into a smart calculator, which can solve for θ.)
Brothas
No values are given, so analytically I suppose. But I get the feeling this spits out a very ugly equation if I do it exactly..
So maybe the answer to this question just is "For a θ which satisfies this equation, the distance is given by r = d + 2Lsinθ"?
Or, maybe, if I assume θ is small, I can get a neat approximate solution?
Maybe something like: C*cotθ = (d+2Lsinθ)² ~ d² for small θ, so θ ~ arctan(C/d²) = arctan(q²/(4π*ε*m*g*d²))?
Suggested for: Electric force question
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
