Homework Help: Electric forces
  1. Sep 3, 2008 #1
    Two small metallic spheres, each of mass
    0.14 g are suspended as pendulums by light
    strings from a common point as shown. The
    spheres are given the same electric charge, and
    it is found that the two come to equilibrium
    when each string is at an angle of 7◦ with the
    vertical.
    The value of Coulomb’s constant is
    8.98755 × 109 N · m2/C2 and the acceleration
    of gravity is 9.81 m/s2 .
    If each string is 13.7 cm long, find the mag-
    nitude of the charge on each sphere.
    Answer in units of nC.
    2. Relevant equations
    y=Tcos(theta)=mg
    x=Tsin(theta)=Fe
    3. The attempt at a solution
    Tcos(7)=(.14g)(9.81)
    T=1.38371
    1.38371sin(7)=.168632
    q=sqrt((.1683632)(2*(.137sin7)^2))/8.98755x10^9
    q=1.44639e-7
  3. Sep 3, 2008 #2
    LowlyPion
    Your method looks fine.
    I haven't checked the math.
    Have you been careful to make sure that the units of grams and cm's is properly matched to the units of g and Coulomb's constant?
    Your answer needs to be in nC.
  4. Sep 3, 2008 #3
    I changed it no nC and that is 1.44641e2 nC. It's still not right. :(
  5. Sep 3, 2008 #4
    sorry i meant *to
  6. Sep 3, 2008 #5
    LowlyPion
    You need to square the total distance between the charges.
