Electric Fusion: Can High Energy Density Electric Fields Work?
In summary, there are many practical difficulties in generating high energy density electric fields. The largest static electric field gradients that we can achieve in an accelerating structure of a particle accelerator is via using standing wave cavity of an oscillating EM field. These fields are prohibitively expensive to construct, and technically unfeasable to generate a static field of the same magnitude.
sid_galt
502
Why can't fusion be accomplished using high energy density electric fields?
I think we call the generators of high density electric fields, Lasers.
But the laser fields vary sinusoidically with time. I am talking about a static field which sort of pushes +ions together. What are the practical difficulties in generating those high energy density fields?
And what device do you think can generate such a thing? Google on the largest static field we have achieved so far.
You will notice that the highest electric field gradients that we can achieved in an accelerating structure of a particle accelerator is via using standing wave cavity of an oscillating EM field. It is prohibitively expensive, and technically unfeasable to construct a static accelerating field of the same magnitude. This is where you are going to be using up more power than you generate, so then what's the point in achieving fusion?
.. and I haven't even mentioned the materials aspect yet that can withstand such high fields without serious breakdown.
Zz.
Thank you for the reply.
What are the methods used for generating high electric fields? Do know a website which can tell me about the methods?
Are static electric forces stronger that magnetic ?
How much voltage are we talking about ?
In order to overcome the coulomb force between two protons you would need an electro static force greater than:
[tex]F = kq^2/r^2 = 9e9*(1.602e-19)^2/e-30 = 230N[/tex] per proton. A proton's cross sectional area is on the order of e-30 m. or less, so you would need a force/area of 2.3e32 N/m^2. Try to achieve that!
The real reason you could never achieve that kind of force with an electro-static field is because coulomb force has to come from electrons or protons. If you think about it, their static field can't produce a force/unit area greater than the force that you are trying to overcome.
AM
RoboSapien,
Actually electric fields and magnetic fields are the same thing.
Magnetic fields are caused by the motion of electic fields.
Relativistic effects make the electric field look like a magnetic field.
Although it is frequently taught that Einstein developed Relativity to
explain the null result of the Michaelson-Morley experiment; Einstein's
true motivation was due to Maxwell's equations of electrodynamics.
The influence of the M-M experiment was rather indirect.
"The influence of the crucial Michelson-Morley experiment on my own
efforts has been rather indirect. I learned of it through H.A. Lorentz's
decisive investigations of the electrodynamics of moving bodies (1895)
with which I was acquainted before developing the special theory of
relativity . . . What led me more or less directly to the special theory of
relativity was the conviction that the electromotive force acting on a
body moving in a magnetic field was nothing else than an electric field.
-Albert Einstein
Dr. Gregory Greenman
Physicist
Morbius said:
... What led me more or less directly to the special theory of
-Albert Einstein
Thanks for the enlightenment sir. Thats going to help us very much in the future.
Magnetic (we've already gotten past the EMF = movement of E fields part) confinement is most difficult because the various reactor designs all have faults that lead to less than optimal Lawson criterion.
Magnetic confinement fusion is like trying to squeeze jello with a cargo net. You need a very dense, indefinitely sustainable confinement field arrangement that can maintain the plasma at the necessary temperatures. Right now the biggest barriers in this regard are costs of materials to build large enough reactors, thermal and shielding limites of materials, and associated changes in magnetic properties.
It's a challenge that requires more resources (time, money, and man/brain-power) than are currently allotted (worldwide) to accomplish this any time in the forseeable future.
Emfuser said:
Is there any other way in which fusion can be achived ? ( except cold fusion )
ZapperZ said:
Zapper,
Exactly.
When magnetic forces are used to confine the plasma - it's called magnetic
confinement fusion.
However, the link above describes the process of "inertial confinement
fusion". One uses lasers, like at LLNL; to implode a small target of fusion
fuel. There's no attempt to contain the plasma - the plasma is contained
due to its own inertia for the brief period of time needed for the reactions
to take place.
The latest fusion laser at LLNL is the NIF - the National Ignition Facility.
This laser, as big as a sports arena; should be powerful enough to actually
achieve fusion ignition:
http://www.llnl.gov/str/September03/Moses.html
One can also do what LLNL does with lasers with big pulsed power
machines like at Sandia. The "Z Pinch" machine in action:
http://zpinch.sandia.gov/Z/Images/z.jpg
This machine puts very large currents into a series of wires. The current
and the magnetic field interact and implode the wire assembly and
compress a fusion target, similar to the way the LLNL lasers do.
Physicist
Hydrogen bombs achieve fusion just fine, they just aren't terribly useful for generating power for peaceful ends.
Fusion CAN be achieved with magnetic confinement, it's just not as easy as one might think when considering the initial ideas. The problems with magnetic confinement right now come down to what I said before: money and materials needed for a proper scale reactor.
Other methods of achieving fusion are inertial confinement (lasers), and inertial electrostatic, which is sort of hard to describe, but the device is small and makes an excellent table-top neutron generator. Unfortunately, we can't yet get a power gain out of any designs.
The Pons/Fleischmann experiements for cold fusion back in the late 80s were just bad science. My fusion prof back in school became visibly angered if you ever brought them up in class. The most promising idea for room-temperature devices for achieving fusion had something to do with imploding bubbles in acetone, but I don't know what progress (if any) was ever made on that one.
Emfuser,
I don't think we can say that "Fusion CAN be achieved with magnetic
confinement.." quite yet. We do not as yet have a proof of principle for
fusion ignition via magnetic confinement.
As we have built larger and larger machines - like the family of tokamaks
at the Princeton Plasma Physics Lab; PLT [ Princeton Large Torus ] and
TFTR [ Tokamak Fusion Test Reactor ]; to name the latest two in the
series - we've seen more and more varied plasma instabilities that have
circumvented our quest for magnetic fusion.
Hopefully, the latest machine - the ITER - will be more successful.
The progress in inertial fusion has been more sustained. Inertial fusion
ignition has been accomplished in the aforemention hydrogen bombs -
but also the progress has been more sustained in the laser fusion arena.
The main problem facing laser fusion was to be able to drive a target
that was big enough - so that it could capture the product alpha particles
and achieve ignition. Calculations indicate that the new LLNL laser -
the NIF [ National Ignition Facility ] will be large enough and powerful
enough to achieve ignition [ hence the name ].
Physicist
Thanks ZapperZ
Morbius said:
Emfuser,
Physicist
Sure you can achieve fusion within current magnetic confinement devices. Whether or not you can achieve breakeven with any current device is a different story. ITER is (and forever will be, at this pace) slated to be the first magnetic confinement device to do that.
Emfuser,
If all you want is fusion reactions - then you don't need any containment
system - magnetic. inertial, or otherwise. You just hit your tritiated target
with a beam of deuterons out of a cyclotron.
Implicit in these discussions about the feasibility of fusion is that we are
talking about breakeven or better!
Otherwise, it's a moot, trivial point.
Physicist
ignoring cold fusion, I follow KISS(Keep It Simple Stupid), and believe Sandia is on the right track with the Z-Pinch and is only holding back since the facility costs billions less than the snotty and arogant physicists at NIF. Wouldn't it be a blow to them is Sandia achieved fusion years before them. Geez, KISS! Esp. since photons are just reactions due to a drop in energy, the real meat is in the mass itself.
Are you referring to Sandia's Z-IFE project, Copious?
I have hopes they may one day be able to fuse light hydrogen atoms with heavier lithium or boron, as that process is aneutronic, and clean - no radioactive waste.
Since this thread was resurrected from the dead, I thought I'd address the OP's point directly.
You can accomplish fusion directly using electric fields. They don't even have to be that high density.
The inventor of television also invented an electrostatic fusion device called the Farnsworth fusor. Sometimes called IEC fusion (Inertial Electrstatic Confinement).
I've personally witnessed running fusion reactors in my friend's personal home labs. You can fuse deuterons easily and reliably with relatively primitive equipment, a vacuum chamber, 1 micron vacuum system, deuterium gas supply, a -30kV power supply, and suitable fittings and guages will do it.
See:
http://www.fusor.net/
http://en.wikipedia.org/wiki/Fusor
Several universities have ongoing fusor research programs, most notably the University of Wisconsin and the University of Illinois Champagne/Urbana.
The problem with this approach, at the moment and for the foreseeable future, is that the energy required to acceleration deuterium ions to achieve fusion with current devices is mostly wasted so that fusors produce microwatt's of fusion with hundreds of watts of input power. The Q or efficiency is far below 1 at this point for even the best fusors.
Some people are working on improving the Q and I find this to be an exciting field as it is one where amateurs can actually make some progress since the devices cost in the thousands of $ rather than millions or billions. But for most people, it's just an interesting hobby rather than a serious attempt at scientific progress.
Yes mugaliens that is the project. Hopefully some day we will hear good news.
1. How does electric fusion work?
Electric fusion is a process that involves using high energy density electric fields to fuse together two atomic nuclei, resulting in the release of energy. This is similar to traditional nuclear fusion, but it utilizes electric fields instead of heat or pressure to initiate the fusion reaction.
2. What are the potential applications of electric fusion?
Electric fusion has the potential to be used as a source of clean, renewable energy. It could also be used in medical imaging and cancer treatment, as well as in space propulsion systems.
3. Can electric fusion be controlled and sustained?
Currently, electric fusion has not been successfully sustained for long periods of time. However, research is ongoing to develop methods for controlling and sustaining the fusion reactions.
4. How does electric fusion compare to traditional nuclear fusion?
Electric fusion has the potential to be more efficient and have fewer safety concerns compared to traditional nuclear fusion methods. It also does not produce radioactive waste.
5. What are the challenges in developing electric fusion technology?
One of the main challenges in developing electric fusion technology is achieving the high energy densities required for the fusion reaction to occur. Additionally, controlling and sustaining the fusion reaction is also a major hurdle that scientists are working to overcome.
  • Nuclear Engineering
