How Should I Determine the Correct Power Rating for a Motor Winding Paper?
In summary, the conversation discusses trying to size a motor for an application involving winding paper with two motors. The worst case scenario is outlined, and the thought process for determining the required motor power is explained. The conversation also brings up questions about the assumptions made and the appropriate size for the motor.
tomizzo
114
Hello,
I'm trying to size a motor for an application that I'm working on.
The application involves winding paper with two motors. One motor will unwind and the other motor will rewind. However, I'm trying to figure out what the motor power rating should be. Here's the worst case scenario:
Very non-elastic paper, winding to a diameter of 15 inches, at 15 lbs of tension at 50 feet per minute.
Here is my thought process, and I would like to know if anyone can pick out any incorrect assumptions.
As the paper is rewinding, the diameter will get bigger. However, because this diameter is get bigger, that means that it will take less revolutions per minutes to obtain a constant tangential speed (feet per minute of paper). In other words, as the diameter of the rewinding paper grows, the RPM of the winding motor will slow down.
Theoretically, this motor should operate at a constant power consumption. This is due to the fact that at a small winding diameter, the motor will not have to supply a lot of torque, but will have a large rpm to obtain the 50 feet per minute tangential speed. But once the diameter grows larger, the RPM will decrease but the torque has to increase since the tension force is further from the center of the motor shaft.
Using the formula that Horse Power = Ft-lbs X RPM / 5252, let's calculate the power when the roll is 15 inch diameter.
The torque required would be 15 lbs at 7.5 inches. This would equate to 9.375 foot-lbs. To achieve a tangential speed of 50 fpm at 15 inch diameter, that would be 50 /( 2 x pi x (7.5/12)). The 7.5/12 represents the radius in feet. This would equate to 12.739 RPM. Putting this into the horse power formula, this would require .02273 horse power.
But my question is, is this number fair enough to determine the power rating? If the motor is accelerating, obviously it will require torque to accelerate it. However, if the motor is moving very slowly and accelerating very slowly, this should be a small force.
So my questions are the following:
Are the assumptions I made above correct? .02273 HP seems very low.
And what would be an appropriately sized motor?
I get roughly the same power (0.02HP) when I did the sums.
That's the power required to turn it at constant rpm. Presumably when the motor starts up it will have to accelerate up to 12rpm in a certain time? To do that it will have to overcome both the 15lbs tension and the inertia of the system (roller, roll of paper, motor, gearbox etc).
It's quite interesting to think about the other motor, the one unwinding the paper. Presumably it's load is also 15lbs of tension in the paper but assisting rotation so it's a negative load. Can you still call it a "motor" :-)
This won't answer your question directly but might help. I work for a web (ie newspaper) printer with a rewinder and only the take up roll is driven. The feed roll has a brake to regulate the tension. The tensile strength of the paper is more than enough.
When the paper is on the press it is being "pulled" through all the rollers and press units at the "folder" where all the webs come together. In our case this can be over 20 metres from the furthest roll-stand. If you look at a newspaper you can see the marks from the knurled rollers that grip the paper.
Haha, no I would probably call that a brake. However, I'm trying to make the set up so that it will work with web heading in either direction. That means that both motors will take turns braking and leading.
Hello,
Your thought process seems to be mostly correct. As the diameter of the rewinding paper increases, the motor will have to supply more torque to maintain the constant tangential speed of 50 feet per minute. This is because the tension force is further from the center of the motor shaft, as you mentioned.
Your calculation for the required power at a 15 inch diameter seems to be accurate. However, it is important to also consider the starting torque and acceleration of the motor. It may require a higher power rating to overcome the inertia of the system and start the motor moving.
In terms of selecting an appropriately sized motor, it is important to also consider the duty cycle of the application and any potential overload conditions. It is recommended to choose a motor with a slightly higher power rating than what is calculated to ensure it can handle any unexpected variations or stresses.
Additionally, it may be helpful to consult with a motor manufacturer or engineer for further guidance and to ensure all factors are taken into consideration when selecting a motor for your specific application.
What is an electric motor power estimate?
An electric motor power estimate is the predicted amount of power that an electric motor will use to perform a specific task. It takes into account factors such as the motor's efficiency, the load it will be moving, and the speed at which it will operate.
Why is it important to estimate the power of an electric motor?
Estimating the power of an electric motor is important because it allows engineers to select the appropriate motor for a given application. It also helps determine the motor's energy consumption and potential operating costs.
How is the power of an electric motor estimated?
The power of an electric motor is estimated by using mathematical formulas that take into account the motor's voltage, current, and speed. These formulas can be found in the motor's datasheet or calculated using known values.
What factors can affect the accuracy of an electric motor power estimate?
Several factors can affect the accuracy of an electric motor power estimate, including variations in the motor's efficiency, the operating conditions (such as temperature and load), and the accuracy of the motor's datasheet information.
Can an electric motor power estimate change over time?
Yes, an electric motor power estimate can change over time due to factors such as wear and tear, changes in operating conditions, or modifications to the motor. It is important to regularly reassess the power estimate to ensure the motor is still operating at its optimal efficiency.
  • Electrical Engineering
