Homework Help: Electric Motor Problem
  1. Oct 20, 2008 #1
    Problem:
    The rotor in a certain electric motor is a flat, rectangular coil with 90 turns of wire and dimensions 2.50 cm by 4.00 cm. The rotor rotates in a uniform magnetic field of 0.800 T. When the plane of the rotor is perpendicular to the direction of the magnetic field, it carries a current of 9.1 mA. In this orientation, the magnetic moment of the rotor is directed opposite the magnetic field. The rotor then turns through one-half revolution. This process is repeated to cause the rotor to turn steadily at 3600 rev/min.
    (a) Find the maximum torque (max) acting on the rotor.
    Nm
    (b) Find the peak power output (max) of the motor.
    W
    (c) Determine the amount of work (W) performed by the magnetic field on the rotor in every full revolution.
    (d) What is the average power (avg) of the motor?
    "Then part C is given by 4(9.1 x 10-3A)(90)(0.025mx0.04m) = 0.00262J"
    The above was asked by another user. I also had this problem and had a question on part C. The user above correctly finds C, I am wondering why the answer is what it is. The rest of the problem makes sense to me. Here's what I have below, I am not sure where the 4 is coming from.
    4NIAB
    Where
    N = number of loops
    I = Current
    A = Area of Loop
    B = Magnetic Field.
    Thanks.
  3. Oct 21, 2008 #2
    alphysicist
    Hi Ithryndil,
    It comes from the potential energy formula for the magnetic moment, which is the dot product of the moment and the B field:
    U= - mu B cos(θ)
    where (mu=NIA) and θ is the angle between the moment (perpendicular to the loop) and the B field.
    Now look at half of a revolution. At the beginning, the moment is opposite the B field. What is the potential energy? After one-half of a revolution, the moment is in the same direction as the B field; what is the potential energy then?
    The work done is the (negative of the) change in the potential energy, so that gives the answer for half of a revolution. Doubling that gives the coefficient of 4 for the full revolution. Do you get that answer?
