- #1
crybllrd
- 120
- 0
Electric charge can accumulate on an airplane in flight. You may have observed needle-shaped metal extensions on the wing tips and tail of an airplane. Their purpose is to allow charge to leak off before much of it accumulates. The electric field around the needle is much larger than the field around the body of the airplane and, can become large enough to produce dielectric breakdown of the air, discharging the airplane. To model this process, assume that two charged spherical conductors are connected by a long conducting wire and a charge of 9.00 µC is placed on the combination. One sphere, representing the body of the airplane, has a radius of 6.00 cm, and the other, representing the tip of the needle, has a radius of 2.00 cm.
(a) What is the electric potential (V) of each sphere?
r = 6.00 cm
r = 2.00cm
(b) What is the electric field (V/m, direction) at the surface of each sphere?
r = 6.00 cm
r = 2.00cm
r1 = 6e-2
r2 = 2e-2
q1/q2=r1/r2
q1=3q2
q1+q2=9e-6
3q2+q2=9e-6
4q2=9e-6
q2=2.25e-6
q1+2.25e-6=9e-6
q1=6.75e-6
v1=kq1/r1
v1=101
When I submit it, it tells me that "Your response differs significantly from the correct answer. Rework your solution from the beginning and check each step carefully."
Any help?
