Understanding Electric Potential Concepts: Help with Multiple Choice Questions
In summary, the person is seeking help with multiple choice questions related to electric fields and capacitors. They provide a summary of their attempts and the correct answers for several questions. They also ask for clarification on when work is positive or negative and receive assistance with one of the questions.
musicfairy
101
I need some help on those multiple choice questions that I'm using to learn the concepts. Some of them I know how to do and needs someone to check my work. Other ones I need hints so I know how to start.
1. Three ½ μF capacitors are connected in series as shown in the diagram above. The capacitance of the combination is
(A) 3/2 μF
(B) 1 μF
(C) 2/3 μF
(D) 1/2 μF
(E) 1/6 μF
I used this equation: 1/Ceq = 1/C1 + 1/C2 + 1/C3 and got E as the answer.
2. In a certain region, the electric field along the x-axis is given by
E = ax + b, where a = 40 V/m2
and b = 4 V/m.
The potential difference between the origin and x = 0.5 m is
(A) -36 V
(B) -7 V
(C) -3 V
(D) 10 V
(E) 16 V
I tried to plug in 0 and 0.5 for x and subtract them but that didn't work out.
3. A 20 μF parallel-plate capacitor is fully charged to 30 V. The energy stored in the capacitor is most nearly
(A) 9x103 J
(B) 9xl0-3 J
(C) 6x10-4 J
(D) 2x10-4 J
(E) 2x10-7 J
Used the equation U = (1/2)CV2 and got B as the answer.
4. A potential difference V is maintained between two large, parallel conducting plates. An electron starts from rest on the surface of one plate and accelerates toward the other. Its speed as it reaches the second plate is proportional to
(A) 1/V
(B) 1 / √V
(C) √V
(D) V
(E) V2
qV = (1/2)mv2
When I rearrange it to isolate v it's proportional to √V so it's C.
5. A solid metallic sphere of radius R has charge Q uniformly distributed on its outer surface. A graph of electric potential V as a function of position r is shown above. Which of the following graphs best represents the magnitude of the electric field E as a function of position r for this sphere?
Electric field in a conductor is 0 and is proportional to 1/r2, so C is the answer.
This diagram is used for the next 3.
6. Which vector below best describes the direction of the electric field at point A?
Electric field directs toward lower potential, so it's D?
7. At which point does the electric field have the greatest magnitude?
(A) A
(B) B
(C) C
(D) D
(E) E
Not sure. How do I start?
8. How much net work must be done by an external force to move a -1 μC point charge from rest at point C to rest at point E?
(A) -20 μJ
(B) -10 μJ
(C) 10 μJ
(D) 20 μJ
(E) 30 μJ
W = qV
= -1(20 - 10)
= -10 μJ
It's B.
Can someone(s) also please explain to me when is work done by field positive or negative? Thanks.
E = dV/dx. So in #2 to get the V you must integrate Edx.
In #6, wouldn't it be A that points toward the lower V - perpendicular to the V line?
In #7, you want the place where the lines of constant potential are closest together so the dV/dx is highest.
So you mean that in #7 B is the correct answer since the potential lines are the closest?
Yes.
How do I do #2?
Use the expression you have for E and perform the integration.
If you have trouble, show your work here so we can see what is going on.
Ok, I see.
V = −∫E∙dr
= −ax2/2 + bx
= −20x2 − 4x
When x = 0.5
V = −7, so B is the answer.
Is this correct?
Yes, that's what I get.
Thank you for your help.
1. What is electric potential?
Electric potential is a measure of the amount of electrical potential energy that a point in an electric field possesses per unit charge. It is a scalar quantity and is measured in volts (V).
2. How is electric potential different from electric field?
Electric potential is a scalar quantity that describes the energy of a charge at a specific point in an electric field, while electric field is a vector quantity that describes the force that a charge would experience at that point.
3. How is electric potential related to electric potential energy?
Electric potential energy is the potential energy a charge has due to its position in an electric field. The electric potential at a point is the electric potential energy per unit charge at that point.
4. How is electric potential calculated?
The electric potential at a point is calculated using the formula V = kQ/r, where k is the Coulomb's constant, Q is the charge, and r is the distance from the point to the charge.
5. What is the difference between electric potential and electric potential difference?
Electric potential is a measure of the potential energy per unit charge at a specific point, while electric potential difference is the difference in electric potential between two points. Electric potential difference is often referred to as voltage and is measured in volts (V).
