Electric Potential Difference
  1. May 10, 2015 #1
    In a TV tube, an electric potential difference accelerates electrons from a rest positive towards a screen. Just before striking the screen, the electrons have a wavelength of 1.0⋅10-10. Find the electric potential difference.
    2. Relevant equations
    Should I use these?
    [tex]\Delta V = \frac{Work}{Charge} [/tex]
    [tex]λ= \frac{h}{\sqrt{2⋅m⋅E}} [/tex]
    3. The attempt at a solution
    substituting/simplifying I came to: [tex]\Delta V = \frac{h^2}{2⋅e⋅m⋅λ^2} [/tex]
    Would this best the correct equation to find the answer?
    ***Corrected the 'E' implying energy to 'e' for elementary charge
    Thanks for your time and help,
    Julian
  3. May 10, 2015 #2
    gneill
    Staff: Mentor
    1.0⋅10-10 what? Miles? Astronomical units? Watermelons?
    :smile: Be sure to include units for every numerical data value!
    The equation that you arrived at looks to be okay. Not sure how you got there from your Relevant Equations though o_O
  4. May 10, 2015 #3
    Sorry about my units... :nb)
    Since [tex]λ= \frac{h}{\sqrt{2⋅m⋅E}} → E= \frac{h^2}{\sqrt{2⋅m⋅λ}} [/tex]
    I reckon: [tex]ΔV = \frac{E}{e} = \frac{(\frac{h^2}{\sqrt{2⋅m⋅λ}})}{e} = ΔV = \frac{h^2}{\sqrt{2⋅m⋅e⋅λ}} [/tex]
  5. May 11, 2015 #4
  6. May 11, 2015 #5
    I was looking at this and my second algebra is terrible... I meant to write this but I was awake for way too long.
    Since [tex]λ= \frac{h}{\sqrt{2⋅m⋅E}} → E= \frac{h^2}{2⋅m⋅λ^2} [/tex]
    [tex]ΔV = \frac{E}{e} = \frac{(\frac{h^2}{2⋅m⋅λ^2})}{e} = \frac{h^2}{2⋅m⋅e⋅λ^2} [/tex]
  7. May 11, 2015 #6
    gneill
    Staff: Mentor
    Good. You've shown your work and it looks fine to me :smile:
    Now, what are the units of the wavelength you've been given? It matters because it will determine the magnitude of the velocity of the electron; you need to be sure that the speed is low enough that relativistic equations aren't required (as it turns out they aren't here, but it is something you should check for every time).
  8. May 11, 2015 #7
    It's meters, and thanks for your help I mostly needed to make sure it was right before I put in the numbers; thats the easy part :p.
  9. May 11, 2015 #8
    Question about significant digits... Is this one significant digit because the question is 1.0⋅10-10m?
  10. May 11, 2015 #9
    BvU
    2017 Award
    I wouldn't worry and quote 150 V: If someone gives 1.0 then in principle you are to assume it's in the range 0.95 - 1.05, so 1.5 102 V would be a good answer.
    Sure, the numbers are the easy part. If you found 150 V like I did (did you ?) I suppose that's what the exercise wants.
    (But that is a funny kind of TV: I seem to remember a color TV has some 25 kV as accelerating voltage. Perhaps they wanted to make sure you wouldn't worry about relativistic corrections... )
  11. May 11, 2015 #10
    ...and wait, isn't electric potential diff in eV.. I jump at the conclusion due to the ΔV symbol and as eV's seem to be standard in this study? ... Thanks for pointing that out.
  12. May 11, 2015 #11
    gneill
    Staff: Mentor
    Electric potential difference has units of Volts, which is equivalent to Joules per Coulomb. eV is a unit of energy alone, i.e. some number of Joules.
  13. May 11, 2015 #12
    I need to learn to read still...
  14. May 11, 2015 #13
    BvU, you're honestly a tank. Thanks dude.
  15. May 11, 2015 #14
    But why the heck does the equation render a value within the realm of the centi-volt? I pull 15078.5 from the equation but I'm not sure the units,
    and if you say its 150 volts, I'm in a new place of confusion.
  16. May 11, 2015 #15
    Thank you for the critical thinking exercise.
  17. May 11, 2015 #16
    gneill
    Staff: Mentor
    Start by writing out the values of all the variables and constants that you are using in the equation. Make sure that they all have compatible units (i.e. don't mix meters and centimeters and so on). You will be able to find the final units if you combine/cancel them as your calculation proceeds.
  18. May 11, 2015 #17
    I might be doing something wrong here, I tried this a couple of ways but I don't exactly line up with [tex] \frac{kg⋅m^2}{A⋅s^3} [/tex]
    I end up with this
    [tex] \frac{m}{A⋅s^2} [/tex]
  19. May 11, 2015 #18
    I'm not sure if you can see where I'm going wrong in my units, I've tried using plancks constant with J/s too but its also not Volts, although I know it is, but where am I going wrong.
  20. May 11, 2015 #19
    gneill
    Staff: Mentor
    Please post the values with units. I can tell you right now that the units of h are J s or kg m2/s, not J/s.
  21. May 11, 2015 #20
    :smile:I forgot to square the planck constant and wavelength when working with the units alone.... Were all good, thanks for the tip, I thought it might be easier to think about working with the units without numbers but I forgot about the powers of the value to begin.. I certainly see the importance of the actual units now, so I really appreciate everyone here drilling that stuff for me. I love this site.
Have something to add?
Draft saved Draft deleted
