Electric Potential Energy of a Charged Particle in an Electric Field
In summary, when a charged particle is released and free to move in an electric field, its electric potential energy will be converted into kinetic energy as it moves to a lower potential. This is similar to a mass object under the influence of a gravitational field. The correct answer in the multiple choice is b.
European Sens
what will happen to the electric potential energy of a charged particle in an electric field when the particle is released and free to move?
2. multiple choice
a. it will increase
b. it will change into kinetic energy
c. it will remain unchanged
i think its "b"
A charged particle in an electric field is like a mass object under the influence of the gravitational field. Once the particle is let go, it will move to lower potential, and its potential energy will be converted into kinetic energy as the particle accelerates.
so i was correct?
1. What is electric potential energy?
Electric potential energy is the energy that a charged particle possesses due to its position in an electric field. It is a form of potential energy, meaning it is energy that is stored and can be converted into other forms of energy.
2. How is electric potential energy calculated?
The electric potential energy of a charged particle can be calculated using the equation U = qV, where U is the potential energy, q is the charge of the particle, and V is the electric potential at the particle's position.
3. What is the difference between electric potential energy and electric potential?
Electric potential energy is a measure of the energy that a charged particle possesses, while electric potential is a measure of the energy per unit charge at a specific point in an electric field.
4. Can electric potential energy be negative?
Yes, electric potential energy can be negative. This typically occurs when the charged particle is attracted to the opposite charge or when it moves from a point of higher potential to a point of lower potential.
5. How is electric potential energy related to electric potential difference?
Electric potential energy is directly proportional to electric potential difference. This means that as the potential difference between two points increases, so does the potential energy of a charged particle between those two points.
