Screwdriver
- 129
Determine an expression for the electric potential at a point P a distance z away from the center of a thin uniformly charged rod on the line that bisects the rod.
[tex]V=k\frac{q}{r}\hat{r}[/tex]
I've defined r to be the straight-line distance from any point, i, on the rod to P and y to be the vertical distance along the rod to i.
Determine the charge due to some point i:
[tex]V_i=k\frac{\Delta Q}{r}\hat{r}[/tex]
I determined that:
[tex]\hat{r}=cos(\theta )=\frac{z}{\sqrt{y^2+z^2}}[/tex]
So:
[tex]V_i=kz\frac{\Delta Q}{y^2+z^2}[/tex]
Then with linear charge density:
[tex]Q=\lambda y\Rightarrow \Delta Q=\lambda \Delta y[/tex]
[tex]V_i=kz\lambda \frac{\Delta y}{y^2+z^2}[/tex]
Then sum those up and take the limit as the sum approaches infinity and as delta y approaches zero:
[tex]V_{net}=kz\lambda \int_{\frac{-L}{2}}^{\frac{L}{2}}\frac{d y}{y^2+z^2}=k\lambda arctan(\frac{y}{z})|_{\frac{-L}{2}}^{\frac{L}{2}}[/tex]
[tex]V_{net}=2k\lambda arctan(\frac{L}{2z})[/tex]
