Homework Help: Electric Potential problem
  1. Nov 4, 2014 #1
    • Use of the homework template is mandatory in the homework forums.
    The electric field at the origin is along the positive x axis. A small circle is drawn with the center at the origin cutting the axes at points A, B, C, and D having coordinates (a,0), (0,a), (-a,0), (0,-a), respectively. Out of the points on the periphery of the circle, the potential is minimum at _______?
    (a) A (b) B (c) C (d) D
    After drawing the diagram, I see that the electric field is directed towards the right along the x-axis (towards A). However, electric potential = KQ/r, and here Q and r are constant for all four points. I don't see how any point could have "minimum" potential.
  3. Nov 4, 2014 #2
    BvU
    2017 Award
    Hello Epic, welcome to PF :)
    Did you notice the template ? Better use it.
    However:
    Your electric potential expression isn't applicable here. There is no mention of Q !
    You want to make use of a different relationship between E and V.
    In the template, there is room for such equations under 2) relevant equations.
  4. Nov 4, 2014 #3
    2. Relevant equations
    V = -E dr
    3. The attempt at a solution
    After drawing the diagram, I see that the electric field is directed towards the right along the x-axis (towards A). But how will integrating the above equation give me the "minimum" potential necessary?
    Thanks for the help
  5. Nov 5, 2014 #4
    BvU
    2017 Award
    Much better !
    Actually, it's ##{\bf d}V = -\vec E\cdot d\vec r\,##. You integrate and get ##\Delta V##, which happens to be just the one you are after !
Have something to add?
Draft saved Draft deleted
