Electric pulse attenuation
  1. Dec 7, 2007 #1
    Hallo to all,
    I have been reading a paper regarding electric pulse attenuation and
    the values are quoted in dB. The conversion to dB was done by
    multiplying the value with (20log10e) where "e" is the base of the
    natural logarithm.
    I see this conversion to dB fist time. I can not find any information
    in my math books or the web.
    Does any of you have any information regarding this that I can read so
    I can understand it better?
  3. Dec 7, 2007 #2
    On Dec 6, 12:37 pm, Efthimios <eangelopou...@gmail.com> wrote:
    > Hallo to all,
    > natural logarithm.
    "dB" is short for "decibel". It is a logarithmic power scale relative
    to some reference power. The most general formula is:
    dB = 10 Log10( P1/P0)
    Where P1 is the power being described and P0 is the reference power
    level. On this scale zero dB means the power is equal to the
    reference power level. 10 dB means the power is 10 times the
    reference level. 20dB means it is 100x the reference level. etc.
    When used often the reference level is not stated explicitely. Really
    it ought to be. In low power RF (radio frequency) electronics they
    often use dBm meaning decibels wrt 1 milliwatt. You also sometimes
    see dBuW (wrt to 1 micro Watt) and dBW (wrt 1 Watt). As electrical
    signals are often measured in volts, you often see decibels defined
    as:
    dB = 20 Log10 (V1/V0)
    This is correct assuming that the impedance of the circuit with V1 and
    V0 are the same, and that the power is related to V^2/R. If the
    impedances are not the same (e.g. between the input and output of an
    amplifier) then this formula is not correct. Decibels are always a
    power ratio expressed as a log.
    There is more on this in the Wikipedia article on
    "decibel" (www.wikipedia.org)
    Rich L.
  4. Dec 8, 2007 #3
    > > Hallo to all,
    > > natural logarithm.
    > as:
    > Rich L.
    Thanks Reich, but have you seen the expression (20log10e) where "e" is
    the base of the natural logarithm.???
    This Log is multiplied with the value of the attenuation to convert it
    to the logarithmic dB.
    I am trying to see where this particular strange (20log10e) expression
    of comes from. This does not look like the normal dB expression that
    you mentioned above.
    Brgds
    Efthimios
  5. Dec 8, 2007 #4
    (on the subject of the decibel)
    Let me add one thing to Rich's excellent summary: While the formula
    10\log_{10}(r) looks completely arbitrary, ratios of 1 dB \approx 1.26
    turn up in a surprising number of places, always in some way associated
    with human perception. The association of dB with audio technology is
    well-known, and the quantization of modern digital volume controls is
    almost certainly 1 dB steps.
    A number of years ago, I needed to design an optical resolution test
    pattern, consisting of different sets of lines with varying pitch.
    After a bit of drawing I concluded that stepping the pitch such that
    it doubled every three patterns was just right. In other words, the
    ratio between two steps was cube root of 2, \aprox 1.26.
    The most surprising occurrence of a dB scale was found when a
    colleague and I attempted to estimate the salary scale at the company
    for which we worked. The annual stockholder's meeting report gave us
    enough information to estimate the salary of the Vice President at the
    top of our reporting chain, and a simple calculation gave us a factor of
    about 1.25 per level of management.
    - Bill Frensley
  6. Dec 9, 2007 #5
    On Dec 7, 10:50 am, "William R. Frensley" <frens...@utdallas.edu>
    > - Bill Frensley
    I recall an article in Scientific American in the 70's or early 80's
    making a similar observation about such random things as the first
    digit of street addresses, the area of lakes (irrespective of the
    units used), etc. It appears that any measurement that spans a
    population of more than a few factors of 10 shows a similar
    logarithmic frequency of the first digit. Not quite your observation,
    but possibly related.
    As for Efthimios' question: I was assuming that the "e" in that
    expression was the voltage (sometimes represented by "e" or "E" for
    electric field. If he is using the natural logarithim, it seems like
    he is doing some conversion from a base 10 log to a base e log, but
    that doesn't make sense for decibels. By definition dB is base 10
    log.
    One point that I didn't cover that might be key to understanding
    this. What makes dB so handy in electronics is that amplifier gains
    and attenuator losses are multiplicative properties. That is the gain
    is 2x or the loss is 0.75x, and to get the output level you multiply
    the input by the gain/attenuation. Since dB is a log of the signal
    level, when working with dB signal levels you add/subtract the gain/
    attenuation to get the output level in dB.
    What you are describing does not make sense to me. If you would like
    me to look at the paper I'd be happy to try to figure out what they
    are doing. That is assuming it is in English, however. I'm an
    American and thus monolingual...
    Rich L.
  7. Dec 9, 2007 #6
    Efthimios wrote:
    >Hallo to all,
    >natural logarithm.
    It looks like is using Nepers, which is the natural log of the power
    ratio. See
    http://www.sengpielaudio.com/calculator-neper.htm
    for details about converting Np to dB.
  8. Dec 9, 2007 #7
    >>> Hallo to all,
    >>> natural logarithm.
    >> as:
    >> Rich L.
    > Brgds
    > Efthimios
    Most likely it comes from the fact that
    20 log10(V1/V2) = 20 log10(e) * ln(V1/V2).
    Note that if V1 is very close to V2, ln(V1/V2) is approximately (V1-V2)/V1.
    Jim E. Black
  9. Dec 9, 2007 #8
    Efthimios wrote:
    > Hallo to all,
    > natural logarithm.
    Not heard of it being done with base e
    http://en.wikipedia.org/wiki/Decibel
    Dirk
    http://www.transcendence.me.uk/ [Broken] - Transcendence UK
    Remote Viewing classes in London
  10. Dec 9, 2007 #9
    Efthimios wrote:
    > Hallo to all,
    > natural logarithm.
    Dirk
  11. Dec 9, 2007 #10
    distribution of leading digits of numbers (was: Re: Electric pulseattenuation)
    Moving distinctly off-topic [[note to moderators: this is arguably
    outside the s.p.r. charter, but does at least supplement an ambiguous
    reference with a solid primary source for anyone wanting more info]]...
    For a detailed discussion (including further references) of the
    logarithmic distribution of leading digits of numbers written in
    scientific notation, see section 4.2.4 of Donald E. Knuth's
    "The Art of Computer Programming, volume 2: Seminumerical Algorithms"
    (3rd Edition, Addison-Wesley 1997 hardcover, ISBN 0-201-89684-2).
    ciao,
    -- Jonathan Thornburg (remove -animal to reply) <J.Thornburg@soton.ac-zebra.uk>
    School of Mathematics, U of Southampton, England
    "Washing one's hands of the conflict between the powerful and the
    powerless means to side with the powerful, not to be neutral."
    -- quote by Freire / poster by Oxfam
  12. Dec 9, 2007 #11
    ciao,
  13. Dec 11, 2007 #12
    In general the income distributions are often
    to a good approximation lognormal.
    (The logarithms of the incomes are distributed normally)
    At the high end this reduces to a power law distribution.
    (Known since the 19th century as Pareto's law)
    The Pareto exponent is a measure of the inequality
    of the distribution.
    Best,
    Jan
  14. Dec 11, 2007 #13
    Hi.
    The 20 factor is when the quantity is an amplitude, not a power.
    Because dB always is log power, to get the dB ratio for one
    amplitude A vs a standard amplitude S, one has to square
    the ratio. Thus 20log(A/S) == 10log[(A/S)^2].
  15. Dec 12, 2007 #14
    > >>> Hallo to all,
    > >>> natural logarithm.
    > >> as:
    > >> Rich L.
    > > Brgds
    > > Efthimios
    > Jim E. Black- Hide quoted text -
    > - Show quoted text -
    Efthimios,
    I got the paper you sent, and Jim Black has the correct answer. The
    parameter they are working with is the propagation constant, gamma =
    alpha +i*beta. The voltage attenuation they are calculating is:
    V = V0*e^(alpha*x)
    So the voltage ratio is:
    V/V0 = e^alpha
    To calculate the dB attenuation per unit length:
    dB = 20*log10(V/V0) = 20*Log10(e^alpha) = 20*Log10(e)*alpha
    Which is what is shown in the paper. The factor Log10(e) comes about
    because dB is defined with Log10, but alpha in the paper was defined
    for an exponential of the natural base (e).
    Rich L.
Similar Discussions: Electric pulse attenuation
  1. Brain electric pulses (Replies: 2)
  2. Attenuation Coefficient (Replies: 10)
  3. Attenuation Length (Replies: 2)
  4. Wave attenuation (Replies: 1)
Loading...
