Homework Help: Electrical Circuit Question
  1. Jan 30, 2013 #1
    http://img15.imageshack.us/img15/771/captureuce.png [Broken]
    Determine if the circuit is valid or invalid.
    2. Relevant equations
    3. The attempt at a solution
    Please note which node I used as the ground node and which node I have labeled [itex]V_{1}[/itex]. By the node voltage method
    [itex]\frac{V_{1}}{8} + 10 - 2 + \frac{V_{1} - 10}{5} = 0[/itex]
    [itex]\frac{13V_{1}}{40} + 6 = 0 [/itex]
    [itex]\frac{13V_{1}}{40} = -6[/itex]
    [itex]V_{1} = -\frac{240}{13} V[/itex]
    [itex]I_{1} = \frac{V_{1}}{8} = -\frac{240}{13*8} = -\frac{30}{13} A[/itex]
    [itex]I_{2} = \frac{V_{1}-10}{5} = \frac{\frac{-240}{13}-10}{5} = -\frac{74}{13}[/itex]
    [itex]I_{3} = 10 + I_{2} = 10 + {-\frac{74}{13}} = \frac{56}{13}[/itex]
    [itex]V = IR[/itex]
    [itex]P = IV[/itex]
    [itex]P = I^{2}R[/itex]
    [itex]P_{8Ω} = I^{2}R = (-\frac{30}{13})^{2}8 = \frac{7200}{169}[/itex]
    [itex]P_{5Ω} = I^{2}R = (-\frac{74}{13})^{2}5 = \frac{27380}{169}[/itex]
    [itex]P_{2Ω} = I^{2}R = (\frac{56}{13})^{2}2 = \frac{6272}{169}[/itex]
    [itex]P_{10V} = IV = \frac{56}{13}10 = \frac{560}{13}[/itex]
    [itex]P_{2A} = \frac{240}{13}2 = IV = \frac{480}{13}[/itex]
    [itex]P_{10A} = IV = 10{-\frac{240}{13}-\frac{74}{13}} = \frac{3140}{13}[/itex]
    These don't add up to zero. I'm kind of confused as to when you are supposed to use a negative sign or not. I used a negative sign in the last calculation because the current is going from lower potential to higher potential. Thanks for nay help you can provide.
  3. Jan 30, 2013 #2
    gneill
    Staff: Mentor
    In your first equation, the final term ##\frac{V_1 - 10}{5}## is not correct. The point where the 5Ω resistor terminates is not at 10V above reference since there's a series resistor of 2Ω in the path. You have two nodes to deal with.
  4. Jan 30, 2013 #3
    Hi gneill,
    Why can't I count the node where the 10 volt source, 5 ohm resistor, and 10 Amp source meet to be 10 volts?
  5. Jan 30, 2013 #4
    gneill
    Staff: Mentor
    You could if the reference node was at the bottom of the 10V source. But it isn't. There's a 2Ω resistor in the way.
  6. Jan 30, 2013 #5
    Ok thanks I forgot about that resistor.
  7. Jan 30, 2013 #6
    http://img59.imageshack.us/img59/1566/capturekwm.png [Broken]
    I believe the picture in this post is accurate. However how would I calculated the power dissipated in the 2A source?
    I know I use
    P = IV
    P = 2(0-(-19.2))
    or
    P = 2(-19.2-0)
    which one is correct?
    Thanks
  8. Jan 30, 2013 #7
    gneill
    Staff: Mentor
    Your node voltages and currents don't look right. Better recheck your calculations.
    If the potential across a current source is negative (if it's driving a current from a higher potential to a lower potential), then it's absorbing energy.
  9. Jan 31, 2013 #8
    What exactly dosen't look right?
  10. Jan 31, 2013 #9
    gneill
    Staff: Mentor
    All the voltages and currents that you've added to the drawing.
Loading...
