What is the discrepancy between two equations for calculating electrical forces?
In summary: L?In summary, the first equation states that the force between two wires is proportional to the inductance and the second equation states the force between two wires is inversely proportional to the distance between the wires.
PlasMav
Hello,
First of all I want to say that I am not an EE, I am an ME but I am working for an EE laboratory on campus and am trying to get a force from and electrical circuit on a project here.
I am using the following equations:
F = 1/2*L'*I^2 (where L' = H/m)
and
F = u_0*I_1*I_2*d/(2*pi*r) (where d = length of conductors and r = their separation distance)
I am trying to get the forces acting upon two parallel conductors with opposite current direction. With my hand calculations and simulation in LTspice I am getting a number greater by a factor of 5 with the second equation than with the first.
I have reason to believe the first equation is not valid for what I want but I want to get a second or third opinion.
Thank you ahead of time!
and
Can you post links to where you got those two equations?
For one thing, the units of the first equation look wrong to me. The RHS has units of energy, not force...
The equation I am using comes from that equation. The difference is L and L'
The L in the energy equation is inductance (Henry) and the L' in the force equation I am using is inductance/distance (Henry/meter).
So since Work or Energy = Force * Distance, Energy/Distance = Force.
Does this make more sense?
The first equation comes from: http://hyperphysics.phy-astr.gsu.edu/hbase/magnetic/wirfor.html
I think that the problem is a misinterpretation of L'. If we denote the separation distance as s (not the d used by the OP), then L'=dL/ds. This is the result obtained if you apply the principle of Virtual Work to the situation. An ME should especially appreciate this approach (yes, I'm an ME also).
JBA said:
PS I am also an ME and get irritated when formulas are given with symbols that are not clearly defined because the author, believes they are obvious to the user.
I think the symbols are defined, provided you subscribe to the common notation that a prime (') represents a derivative. Of course, dL/ds would be more obvious, but it takes more time to write and most of us don't want to invest that time. It all depends on where the individual is coming from.
I understand, and need to clarify my comment because it was not related to any of the information or formulas posted in this thread.
My comment was the result of my frustration during a search of the web to find information on this subject. There were a number of referenced sites that discussed all of the elements of the issue and included a number of formulas and derivations comprised totally of symbols with no definitions their units. I understand the brevity in our forums' posts, but I expect the symbols in equations in published papers and references to be clearly defined.
My apologies. I believe L' was not meant to be a derivative, just another variable separate from inductance. View it as a 'distributed inductance' along the conductor. For any length of the conductor, there is a certain inductance per meter. This is what L' is. The separation distance was not involved in this equation, only the other equation.
This notation was not my own doing, it was given to me as such.
I think this one is approximately correct but I struggle with the symbols.
Field of an infinitely long wire = (mu I) /(2 pi D), where for mu I mean the permeability of free space.
Force on a wire in a given field = I L B
Force = I L mu I / 2 pi D = mu I^2 L / 2 pi D (approx)
Note: it looks as if you found formulas using L to mean length and also inductance.
That is from here
Each formula is from a different place. The only length I have is 'd' in the second formula. L' is inductance per length.
So which force is most valid for lateral force between conductors?
In my opinion the first equation it is still possible[except the factor 1/2!].
Instead of ΔL I put "lng" in order to avoid confusion. Then the force formula it is:
F = μo*I1*I2*lng/(2*pi*r) or:
F = μo*I1/(2*pi*r)*I2*lng but:
B(r)=μo*I1/2πr then:
F =B(r)*I2*lng
B(x)=μo*I1/2πx magnetic flux density at distance x from the first conductor center.
Φ(r)=ʃB(x)*lng*dx|x=ro to r] where ro it is conductor radius and r it is distance center-line to
center line.
L(r)=Φ(r)/I1
dL(r)/dr=B(r)*lng/I1 then:
B(r)=dL(r)/dr/lng*I1
and substituting in above formula we get:
F=I2*dL(r)/dr*I1
If L(r)=μo/2π*lng*LN(r/ro) where ro it is the bare conductor radius or:
L(r)=μo/2π*lng*[LN(r)-LN(ro)] then
dL(r)/dr=μo.lng/2πr
F=μo.lng/2πr*I1*I2 the same formula as above.
1. What is the definition of Electrical Forces Discrepancy?
The electrical forces discrepancy refers to the difference between the expected and observed behavior of electrical forces in a given system or scenario.
2. What causes Electrical Forces Discrepancy?
Electrical forces discrepancy can be caused by a variety of factors, such as errors in measurements, incorrect assumptions or models, or the presence of external forces or influences.
3. How is Electrical Forces Discrepancy measured?
Electrical forces discrepancy is typically measured by comparing the expected and observed values of electrical forces using mathematical calculations or experiments.
4. What are the potential consequences of Electrical Forces Discrepancy?
Electrical forces discrepancy can lead to inaccurate predictions and understanding of electrical systems, which can have practical consequences in fields such as engineering and technology.
5. How can Electrical Forces Discrepancy be minimized or avoided?
To minimize or avoid electrical forces discrepancy, it is important to carefully design experiments and models, use accurate measurements and data, and consider potential external factors that may affect the system.
  • Electrical Engineering
