Can Cars Cause Electrical Interference with Streetlights?
In summary, it was discovered that a car's ignition system can cause interference with electromagnetic devices, potentially affecting the operation of streetlights with unshielded circuits or sensors. However, it was also noted that headlights shining on or reflecting to the streetlights' daylight sensors can also cause them to turn on or off. The conversation also included discussions about the placement and maintenance of light sensors and the possibility of the speaker being the "God of streetlamps".
Gnophos
This is going back a ways, but we used to have a car (I think it was the '89 Camry) that seemed to affect our streetlights. The lights often seemed to go on or wink out as we passed under them.
Was this one of those you-wouldn't-see-it-if-you-weren't-there things, where it only seems to be related to your presence because you were present to observe something that's always occurring anyway, or can a car actually affect a somewhat unstable electrical system like some cheap streetlights?
The ignition system in gasoline cars pulses a very high voltage down the spark plug wires to allow the electricity to jump the gap at the end of the spark plug.
If the spark plug wires are not properly designed and shielded (or old age has caused them to breakdown), they can cause all types of interference with electromagnetic devices like TVs or radios. If the street lights had a circuit on them to determine when to turn on/off, its possible the circuit (or a sensor) wasn't shielded and when presented with the interference it behaved oddly.
Its typically blocked by the metal body of the car, and if you look at older Corvettes (all had plastic bodies) they had an additional metal cover over the ignition distributor to help shield this noise.
Well I've seen this before. It's not the electrical noise of the car that causes the lamps to go off. It's your headlight shining on or reflecting to the street lights daylight sensor. If you notice, you can see the photoelectric sensors that are usually mounted above the lamps.
Precisely!
Didn't Einstein have something to say about keeping problems simple? :smile:
I would have thought it logical to mount an ambient light sensor outside of the range of headlights for that reason, but then again maintenace would be more difficult and maybe the car in question had headlights that were misadjusted?
Well, the headlights were perfectly normal, I think, but that sounds like the answer. Duh! Although I don't see it happening now with our other cars, it could just be a different kind of headlight that doesn't trip the light sensor.
I still think the electrical leakage idea is cooler, though. :)
I am crushed. Disillusioned.
I have been sure for many, many years now that I am the God of streetlamps, and they have been bowing to me.
Now I'm finding out it's not just me?
Actually it IS you. The above was just to placate Gnophos. :biggrin:
: relieved :
1. What is electrical leakage from cars?
Electrical leakage from cars refers to the unintentional loss of electrical current from a vehicle's electrical system. This can occur due to various reasons such as faulty wiring, damaged components, or corrosion.
2. How can I tell if my car has electrical leakage?
There are a few signs that may indicate electrical leakage in a car, such as a dead battery, flickering lights, or a burning smell coming from the vehicle. It is important to have a professional mechanic diagnose the issue to ensure proper repairs.
3. Is electrical leakage dangerous?
Electrical leakage can be dangerous as it can cause malfunctions in the car's electrical system and potentially lead to a fire. It is important to address any signs of electrical leakage promptly to prevent any potential hazards.
4. How can I prevent electrical leakage in my car?
Regular maintenance and inspections of the car's electrical system can help prevent electrical leakage. This includes checking for any damaged wiring or components, ensuring proper connections, and replacing old or worn out parts.
5. Can I fix electrical leakage in my car myself?
It is not recommended to try and fix electrical leakage in a car yourself. This can be a complex issue and requires specialized knowledge and equipment. It is best to have a professional mechanic diagnose and repair any electrical leakage in a car.
  • General Engineering
  • Electrical Engineering
18K
