What is the dielectric constant of the material between the plates?
In summary, the conversation discusses the concept of electrical potential, specifically in relation to a parallel-plate capacitor and a series of points with different potentials. The first question involves finding the dielectric constant of a material used to fill the gap between the plates, while the second question requires using equations to determine the electric potential at a given point.
jpjp
electrical potential help..urgent!
1) A parallel-plate capacitor is made of two flat metal plates pressed against a thin slab of dielectric material. The capacitor is connected to a power supply, and a potential difference of 100 V is applied to the plates. With the power supply disconnected, the dielectric material is removed and the potential difference between the plates is measured to be 500 V. What is the dielectric constant of the material that was initially used to fill the gap between the plates?
2) Points A and B have electric potentials of 275 V and 129 V, respectively. When an electron released from rest at point A arrives at point C its kinetic energy is KA. When the electron is released from rest at point B, however, its kinetic energy when it reaches point C is KB = 4KA. What is the electric potential at point C?
1) Here are some hints:
First, the voltage of a capacitor is equal the the charge divided by the capacitance, or [tex]V=Q/C[/tex]
Second, charge is always conserved, in everything physics(so far at least), so that's a constant you'd want to use.
Last, the dielectric changes the capacitance according to the equation: [tex]C=k \epsilon _0 A/d[/tex] where k is the dielectric constant you're looking for. (A and d stay the same in with or without the dielectric in this case)
2) qV=energy, where q is charge and V is the potential difference. Using this equation you can find the difference in energy from the path from A to C and from B to C, and then work from there.
If you need more help than these admittedly vague hints, I'll give a solution, but it's always best to solve things for yourself.
i get the second problem and thanks for explanations. but for some reason i still can't figure out the first one.
For the first question, put the second equation fluxC gave you into the first one ie.
[tex]V=\frac{Qd}{k\epsilon_0A}[/tex]
Now everything there stays the same except V and k so you could rewrite the equation as
[tex]V=\frac{C}{k}[/tex]
Where C is a constant. You also know that if k=1 (ie. no dielectric present) V=500, so you can solve for C. Then let V=100 and find k.
1. What is electrical potential?
Electrical potential, also known as voltage, is a measure of the electric potential energy per unit charge at a specific point in an electric field.
2. How is electrical potential measured?
Electrical potential can be measured using a voltmeter, which measures the difference in electrical potential between two points in an electric circuit.
3. What is the unit of measurement for electrical potential?
The unit of measurement for electrical potential is volts (V), named after Italian physicist Alessandro Volta who invented the first battery.
4. How does electrical potential affect current flow?
Electrical potential is directly related to current flow, as an increase in electrical potential will result in an increase in current flow, and vice versa.
5. What factors affect electrical potential?
The two main factors that affect electrical potential are the amount of charge and the distance between charges. Other factors include the type of material, temperature, and the presence of other electric fields.
