Electrical Power Related
  • Thread starter ximath
I am studying DC circuits and trying to derive formula for power; that is in fact
[tex]P = I.Vab[/tex]
where Vab is the potential difference between two terminals of a circuit element.
From my previous studies, I know that.
[tex] P = dW / dt [/tex]
I assume that for a small interval, dt, a single charge q has a small displacement , dx.
Then;
[tex]dW = E q dx[/tex]
where E is magnitude of the electric field.
Hence, from the formula above,
[tex] P = E q dx / dt [/tex]
This is all I could come up with. I want to go on with this idea to prove
[tex] P = I Vab [/tex]
I know I need to substitute dq somewhere (to get I ) , somehow.. Simply replacing q with dq does not seem to work; it leads to an incorrect formula. (I find P = I dV ; I guess, if I do that.)
Answers and Replies
MATLABdude
...I assume that for a small interval, dt, a single charge q has a small displacement , dx.
Then;
It would be more advantageous to assume that you have a differential charge dq moving a distance x in the electric field E. (And does dq/dt ring a bell?) Also I believe this approach is more correct, since you have numerous charges (instead of a single one) and you're attempting to find their aggregate behaviour when you use Ohm's law.
This derivation is also a very macroscopic one; the standard first-principles approach is given at Wikipedia:
http://en.wikipedia.org/wiki/Ohm's_law
Related Threads on Electrical Power Related
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
