Electricity and Magetism
  1. Feb 19, 2008 #1
    A point charge Q is imbedded at the center of a uniformly charged spherical distribution of charge Q'= -Q with radius 'a'. Write down the volume charge density for this negatively charged sphere. Calculate the electric field and the potential inside, and outside, the atom.
    2. Relevant equations
    I'm concerned that I do not have the correct electric field. I believe that the electric field inside the sphere should be zero, but I do not completely understand why. Though I do understand that when the E-field is zero, then the Potential will be constant.
    3. The attempt at a solution
    For the volume charge density of the the negatively charged sphere:
    -Q = rho*volume of the sphere, where rho is the volume charge density
    -Q = rho*4/3*pi*a^3
    thus rho = -Q/(4/3*pi*a^3)
    then to find the E-field of the sphere considering the point charge, Q, and the negatively charged sphere I found the total charge Q(r):
    Q(r) = Q + rho * 4/3*pi*r^3 , where r is some arbitrary radius, r could be greater than or less than 'a'
    Q(r) = Q + [-Q/(4/3*pi*a^3) * 4/3*pi*r^3
    thugs Q(r) = Q - Q(r^3/a^3)
    Then for the E-field:
    Integrating E*dA = Q(r)/eo; (where eo is the constant epsilon not)
    I get E = Q/(4*pi*eo)[1/r^2 - r/a^3] for r>a and then when r<a then E=0 right???
    From here I'm pretty sure I can find the potential, (when E is not zero) but I'm just not sure if I have it right. Thank you for your help!
  3. Feb 20, 2008 #2
    Shooting Star
    Why should it be zero?
    The volume charge density is to be calculated over infinitesimal volumes, and so need not be constant.
    No; the other way round. For points outside the sphere, the total charge enclosed by a Gaussain surface is zero.
  4. Feb 20, 2008 #3
    Thanks so much! I thought I had it backwards but a study partner was adamant that it was E=0 for r<a.
  5. Feb 21, 2008 #4
    electric field is zero when there is no charge enclosed (Gauss' Law)
    what I understand from "uniformly charged spherical distribution" is a non-conducting sphere with charge on every piece of it. So electric field inside cannot be zero.
  6. Feb 21, 2008 #5
    Shooting Star
    In this case, would it hold outside the body if the charge distribution on the nonconducting body is uniform but the shape of the body has been changed into an ellipsoid or some other shape?
