How to Calculate Resistance and Current in a Parallel Circuit
  • Thread starter coolnufc
  • Tags
    Electricity
In summary: Ohm's law to calculate the current flowing through the network. Use...Ohm's law to calculate the current flowing through the network.
coolnufc
23
Im stuck on this question.
There is a image of a network. P-Q-R
P goes to Q, and then splits into 2 routes into R.
On each route there is a resistor.
The resistor P-Q is 5 ohms, and the resistors on the 2 different routes Q-R are 3 ohms, and the other is 6 ohms.
The p.d. across PR is 14 volts.
Calculate
a) the equivalent resistance of network QR.
Wouldnt this just be 9ohms. 6+3?
b) the current flowing through PQ.
i did 14/5 = 2.8A
c) the p.d across PQ.
really confused, why is it not just 14V
d) the current through the 3 ohm resistor.
i did 7/3 = 2.3A
I used the equation R = V/I
No. You have to consider how the resistors between Q and R are connected.
i did 14/5 = 2.8A
No. 14V is the potential difference across PR, not PQ.
Because that would mean that the potential difference across QR is zero, and hence no current flows through the entire network.
i did 7/3 = 2.3A
Where does 7/3 come from?
No idea. I am really confused.
OK, start with a. How are those two resistors connected?
Its hard to explain. P is connected to Q with a resistor in the middle. then Q goes in two different routes to R. One resistor on each route. One resistor is 3ohms, then other is 6ohms. and the resistor between P and Q is 5 ohms.
No it's not, you've got 2 choices:
1.) They are connected in series.
2.) They are connected in parallel.
Can you tell me which?
the resistor connecting P and Q is in series.
The two resistors connecting Q and R are in parallel.
Right. And how do you compute the equivalent resistance of two resistors in parallel?
Is the answer 2?
Yes. Do you understand why?
yeah i do. but I am still confused with the other questions.
why is 14V not across PQ as well as the whole thing, it hasnt split into parallel yet?
Because that would mean that the potential difference across QR is zero, which means that no current flows through them. But that is impossible because of conservation of charge at junction Q. Part of the 14V is across PQ and part of it is across QR.
So for part b tell me this: What's the equivalent resistance of the entire network?
Umm, well i came out with two answers. :S
I got 1.43. and then i tried another way and got 6.43.
I have no idea of what you're thinking unless you show how you got those numbers (both are wrong).
well on part a. i did 3 x 6 / 3 + 6. so i tried that for part b. by doing 3 x 6 x 5 / 3 + 6 + 5 = 6.43.
and then i did 1 / (1/6 + 1/5 + 1/3) = 1.43.
Im not sure how to do it because one is in series and one is in parallel.
So to work out the current i need the p.d and the resistance.
I know the resistance of PQ is 5? I just need to work out the p.d?
7? wild guess.
Yes, it's 2 ohms. Why are you guessing? Weren't you taught how to find the equivalent resistance of two resistors in series?
Now that you have the total resistance of and the potential difference across the network, use Ohm's law to determine the total current passing through the network.
No i haven't been taught it. I found something on a website about it.
So i just use the p.d the questions gave me. 14 volts?
So 14/7 = 2A?
Thank you so much, you have been a massive help. I think i understand it a lot more and i will check that website out. I was used examstutor because our school signed us up to it.
Do you have any ideas about this?
a ) How would the resistance of a piece of wire change if
i) the length were doubled? stay the same? probably not.
ii) the diameter were doubled? would it get less?
Use the website I gave you. Everything you need to answer that question is there.
1. What is electricity and how does it work?
Electricity is a form of energy that results from the flow of electric charge. It is produced by the movement of electrons, which are negatively charged particles, through a conductive material such as a wire. This movement of electrons creates an electric current, which can power electrical devices.
2. What are the different types of electricity?
There are two main types of electricity: AC (alternating current) and DC (direct current). AC electricity is the type that is provided by power companies and is widely used in homes and businesses. DC electricity is commonly used in batteries and smaller electronic devices.
3. What is the difference between voltage, current, and resistance?
Voltage is the measure of the electrical potential difference between two points in a circuit. Current is the flow of electric charge through a conductor, measured in amperes (A). Resistance is the opposition to the flow of electric current, measured in ohms (Ω). These three factors are related by Ohm's Law: V=IR, where V is voltage, I is current, and R is resistance.
4. What are the safety precautions for working with electricity?
When working with electricity, it is important to always follow safety precautions to avoid electrocution or fire. These include wearing protective gear, such as rubber gloves and safety glasses, ensuring that all equipment is properly grounded, and never working on live circuits. It is also important to turn off the power before working on any electrical systems.
5. How can I troubleshoot common electrical problems?
If you are experiencing electrical issues, it is important to first check if the problem is with a specific device or the entire circuit. You can use a multimeter to test for continuity, voltage, and resistance. If the issue is with a specific device, you may need to replace it. If the issue is with the circuit, you may need to check for loose connections, faulty wiring, or tripped circuit breakers. If you are unsure, it is best to consult a licensed electrician.
