Electromagnetic Energy: Learn the Basics
In summary, the amount of electromagnetic energy required to hold a ferrous mass suspended in gravity is zero, as the mass does not move. However, if the magnet picks up the mass and accelerates it through the air, there may be a decrease in current due to work being done. This effect is important in MRI machines and is corrected through the use of coils wound in opposite directions.
Austin0
1,160
Electromagnet energy ?
Hi i have very little knowledge of electrodynamics so this is probably a no brainer but:
Given an electromagnet holding a ferrous mass suspended in gravity is the electric energy required exactly equivalent to the basis draw with no mass load??
Thanks
The energy needed to do something is the applied force multiplied by the distance moved (in the direction applied). Since the suspended mass does not move... the electromagnetic energy needed to hold it there is zero.
Thanks
Does this imply that if the magnet picks something up off the ground through the air that there would be a current increase during the acceleration because work was being done?
Austin0 said:
Thanks
If you will take a magnet and a small piece of iron,for example. Then you may put the piece of iron on a table and try to pick it up by your magnet. Eventually, you will be able to change the position of the piece by lifting in up. At first glance, it seems that you magnetic field did some work. But, there is an energy stored in the magnetic field of your magnet u = B*B/2μ. where, u - energy density, B - magnetic field , μ - magnetic permiability in μ0 units. So, If you will add a piece of iron, it will alter the total magnetic field, so increasing of the potential energy of the piece of iron will be canceled by the decreasing of the magnetic field of the system (magnet + iron).
As a conductor moves towards a magnet, there will be an induced current - sure.
I believe your question has been answered - you can imagine that there is some caution about answering questions about "energy of magnets" since they usually come from free-energy advocates.
Typically it would be a current decrease, but yes. This is actually an important effect for MRI machines. Say you have a MRI scanner installed next to an elevator shaft. As the elevator comes near the magnet work is done on the elevator, the current in the coil drops, and the field is reduced. This causes visible artifacts in the images. To correct it, the MRI system has coils wound the opposite way so that as the field of one goes up the field of the other goes down.
What is electromagnetic energy?
Electromagnetic energy is a type of energy that is created by the movement of electrically charged particles. It includes both electric and magnetic fields and travels through space in the form of waves.
How does electromagnetic energy differ from other types of energy?
Unlike other forms of energy, such as thermal or kinetic energy, electromagnetic energy does not require a medium to travel through. This means that it can travel through a vacuum, such as outer space.
What is the electromagnetic spectrum?
The electromagnetic spectrum is the range of all types of electromagnetic radiation, from radio waves to gamma rays. It is divided into different regions based on the frequency and wavelength of the waves.
How is electromagnetic energy used in everyday life?
Electromagnetic energy is used in a wide variety of everyday technologies, including radio and television broadcasting, cell phones, microwave ovens, and X-ray machines. It is also used in medical treatments, such as MRI scans and radiation therapy.
What are the potential dangers of exposure to electromagnetic energy?
High levels of exposure to electromagnetic energy can be harmful to living organisms, causing damage to tissues and cells. However, the levels of electromagnetic energy used in everyday technologies are generally considered safe for human exposure.
  • Electromagnetism
9K
  • Mechanical Engineering
  • Electromagnetism
  • Quantum Physics
  • Quantum Physics
