Electromagnetic brain?
  • Thread starter termina
"Electromagnetic" brain?
Hello there!
It's a fact that our brain emits an (weak) electromagnetic field.
But do you know its precise intensity and its frequency (in Hertz)?
Answers and Replies
berkeman
Mentor
60,860
11,244
Hello there!
Our brain does not really "emit" anything (unless you have a mainstream journal reference for that "fact"). You can monitor the brain's electrical activity in a primitive fashion using the EEG:
http://en.wikipedia.org/wiki/Eeg
You can also gain other insights into brain function using PET scans:
http://en.wikipedia.org/wiki/Neuroimaging
Hello there!
Berkeman is right; it's a common misconception that we have some kind of organized emmisions. Remember, the heat we emit (waste heat) is in the EM spectrum too. We emit a wide variety of waste, but much in the form of heat (IR).
It should be noted that this is like any other waste heat; disorganized, adding to the entropy of a given system.
~10-12T ~10 Hz
http://scholar.google.com/scholar?q=magnetoencephalography&hl=fr&btnG=Rechercher&lr="
I really don't understand your point. Of course the brain emits electromagnetic fields. Of course it's organized enough to reflect the organization of the underlying brain activity. What's the problem exactly?
Evo
Mentor
23,538
3,173
Posting a google search with nothing specific is not acceptable. Make a specific stance and back it up with a specific peer reviewed study so we have some idea of what you are referencing.
berkeman
Mentor
60,860
11,244
~10-12T ~10 Hz
Sigh. What kind of radiated EM field intensity does a uV 10Hz oscillator emit from a 0.1m antenna. Nada.
You need galvanic contact for EEG measurements, right?
EDIT -- beat out by Evo, yet again!
berkeman
Mentor
60,860
11,244
Jeeze Lievo, please make your points more clear next time. It took me multiple reads to finally find the link you had in your "Well" comment. Yes, magnetoencephalography is an interesting technology, but it is only practical in highly shielded and instrumented rooms, not in the real world. The OP implied that there were detectable "emissions" in the real world. MEG is not practical outside of highly shielded and instrumented rooms, AFAIK.
Detecting pT signals at 10Hz is incredibly non-trivial.
My specific stance is that there is several tenth thousands of peer reviewed papers that have analysed a signal Bekerman said does not exist. My answer was deliberatly not too explicit as a mean to not be too rude. I'll be more explicit next time.
A signal expressed in Tesla is not something you can collect from EEG, right?
This was true and it's false for maybe 10-15 years. The need for shielding dramatically decreased since the devices rely on paired sensors so as to cancel far-coming emission. It's still better to shield, but you can remove the highly now.
I'm not sure where you see that in OP's question nor what do you mean by real word, but if you think PET is real word and MEG is not I suggest you have a look at the numbers of studies published in the last five years using either MEG or PET.
Again I don't know what incredibly non-trivial means for you. In some sense I can agree, but there is no doubts it's both easier and cheaper to experiment with a MEG than with PET, so I don't see your point.
But anyway, so what? The OP asked for the amplitude and frequency of this signal. This is a scientifically sound question and the answer is not controversial, so again what's the problem?
berkeman
Mentor
60,860
11,244
Incredibly non-trivial means electrically and magnetically shielded medical rooms for measurements. What do you think the OP intended with his question?
berkeman
Mentor
60,860
11,244
Out of those tens of thousands, could you please post your top ten links? Remember that links must be from peer-reviewed journals here on the PF.
Pythagorean
276
Theres a thread by Q Goest in the Medical Sciences forum that implies a role for the brains gobal electric fields.
Pythagorean
276
Nismara, could you include a point/argument with your links? Most of us know about entropy, but we can sill imagine a physical system that produces coherent field effects. (we all know of several intentionally engineered systems that do so).
I think he intended to ask the precise intensity and frequency of the (weak) electromagnetic field generated by the brain.
To be completely clear: your initial answer to this was the brain does not emits anything, and it was wrong. Now you've changed to yes but the signal is weak, I do agree. You may wish to notice that the OP himself mentionned it was weak, in the opening post.
It has escaped both your attention and Evo's that the link I posted is a search using scholar.google.com, which is an engine devoted to academic stuff only (mostly peer-reviewed papers, plus some book chapters, abstract and posters). It's quite the same as doing a pubmed search, except it takes 15 seconds instead of 5 minutes. If you didn't know that engine, I recommand you give it a try.
Topsy dopsy you still haven't been rebuted, despite I refered to academic materials and you're not. BTW. To be completely clear this time: your suggestion that magnetic fields from the brain are dissipating processes is wrong, which is demonstrated each time a peer-reviewed paper report results collected using MEG. If you follow the link I posted, you'll realized this happens quite often.
Yes but it'd hardly applies. In the paper you're talking about it's mentioned that the neuronal electric fields are just intense enough to impact the firing locally. However the induced magnetic field are far less powerfull than the electric fields, so we should not expect it to have any effects. Unless there is a hidden surprise to find, of course.
My point was what I made earlier, but I was asked what the hell I meant by "disorganized", and waste heat, so I linked. It wasn't meant for anyone but Lievo... I know for a fact that you dont need it.
That said, are you really impressed by possible non-local correlations in a lab, in DNA cultures, that may or may not be QM related? To go from there, to where Lievo is leading, is a winding road with dead ends at every turn.
Ummm... I can't claim this ia friendly, but a bit of advice: don't insult the mentors.
Your academic materials are woefully insufficient, and your point diverges from their claims to the point of absurdity. By the way, I didn't know you were Danish; in English it's, "topsy turvy"... and still doesn't work here.
:rolleyes: Yeah... I've worked with one... BIG... HEAVILY shielded, in a shielded room; it doesn't change the nature of a dissipative process. If you don't think it's that... what do you think our waste heat IS?... how are we alive?
:uhh: It was informative; nothing applies to the magic you seem to believe in.
possible non-local correlations in a lab, in DNA cultures, that may or may not be QM related? To go from there, to where Lievo is leading, is a winding road with dead ends at every turn. (...) nothing applies to the magic you seem to believe in.
I'm talking about MEG, refering to peer-reviewed material, and you read magic and 'DNA QM related' stuff :confused:
I think the mentors can recognized when they are wrong and behave as a function of the rules they are supposed to defend. If I'm wrong that will be one professional scientist less on this forum and you'll have more space to discuss your magic DNA QM related thing you seems to see somewhere.
No, I'm referring to the OP study, your talk of MEG is simply diversion that doesn't have any relevence.
The OP did not mentionned any study. MEG is the only device that can detect the magnetic fields emited by the brain -the ones you said does not exist.
The OP did not mentionned any study. MEG is the only device that can detect the magnetic field emited by the brain -the ones you said does not exist.
Oh hell... I mixed up this thread with the "non-local effects" thread. :redface:
OK... this was my bad.
To MEG: the point remains, it's still a dissipative process, hence the need for immense resolution and shielding to wade through the waste heat and get to the ongoing activity.
Heat does not affect the magnetic fields recorded in MEG in any way. The shielding is a magnetic shielding, again a small one, that is there only to cancel the far-coming magnetic noise, and this has nothing to do with heat dissipation. The need for resolution is because this kind of signal does not carry a lot of energy -again a reason why this has nothing to do with dissipation- but on the other hand the signal is known to be directly tied to the ongoing activity -which is why it is organized/of low entropy. The main reason for the latter is that neither the tissue nor the skull blur this signal (contrary to EEG signal) so what you get is quite directly what has been produced.
berkeman
Mentor
60,860
11,244
My posts were from the position of S/N, and to discourage pseudo-scientific beliefs. The brain does not emit anything that is measurable in the real world. In a shielded lab setting, or with galvanic contact EEG, sure, you can measure crude/gross electrical activity. That's what lab setups are for.
I believe it is important to be clear in what we post and say, otherwise folks with less training in science may latch onto what we say, and believe more in pseudo-science. You're not going to be reading somebody's thoughts from "emitted" EM waves if you're not in a highly shielded room and using large detectors, for example. But yes, given the right shielding and instrumentation, we do have some interesting and developing windows into how the brain works, and into people's thoughts...
Ok I do understand the problem now. However, I don't think it makes any good to hide reality on the basis someone will not understand it properly. So maybe a better way would have been to say:
Yes, there is a magnetic field (~10-12T ~10 Hz) which can be recorded above the head using our best technology, but beware that the intensity fall as the squared of the distance. That means that even supraconducting sensors -which are several order more sensitive to magnetic field than anything else- will not detect anything if farer than say, 10 cm from the scalp.
berkeman
Mentor
60,860
11,244
I like that.
Now that is something we can agree on.
Related Threads on Electromagnetic brain?
  • Last Post
  • Last Post
10K
  • Last Post
  • Last Post
  • Last Post
16K
  • Last Post
  • Last Post
  • Last Post
