lha08
- 164
So in my textbook, they talk about have 2 coils; a primary coil that is connected in series with a battery and a switch, and a secondary coil in which is connected to a galvanometer. Now it says that when the switch in the primary circuit is closed, the meter in the secondary deflects for an instant. And when the switch is opened, the meter again has a momentary deflection.
I'm trying to understand it and this is what i think but not sure if it's correct: like when they close the switch, a current begins to build up in the primary circuit and begins to create a magnetic field. In the secondary circuit, since it's beginning to feel the effects of the magnetic field from the primary circuit, it wants to create an induced current and induced magnetic field in order to sort of negate the effects that it's experiencing. So if the magnetic field begins forming from the primary circuit and is directed downwards,then the secondary circuit will create an induced magnetic field upwards in order to them to sort of cancel...does this make sense? Am I confusing the terms induced current and induced magnetic field?? :S
Thanks
