Electromagnetic rail gun
  • Thread starter kavamo
kavamo
45
An electromagnetic rail gun can fire a projectile using a magnetic field and an electric current. Consider two parallel conducting rails, separated by 0.575 m, which run north and south. A 49.0-g conducting rod is placed across the tracks and a battery is connected between the tracks, with its positive terminal connected to the east track. A magnetic field of magnitude 0.750 T is directed perpendicular to the plane of the rails and rod. A current of 2.00 A passes through the rod.
If there is no friction between the rails and the rod, how fast is the rod moving after it has traveled 8.00 m down the rails? What direction is the force on the rod?
F = qVxB (where V and B are vectors)
F = I LxB
a = ILB / m
a= (2.0 A)(0.575m)(0.750T)
a = 0.8625 m/s
I've drawn the picture and can determine (see) that the force in in the North direction. So I just need help figuring out the acceleration. I think there must be some cross products but don't really understand how to do that.
Thanks in advance for your help.
Answers and Replies
ideasrule
2,284
Didn't you already calculate the acceleration? The unit should be m/s^2, not m/s.
kavamo
45
Sorry, I got confused.
So then to answer the actual question I multiply 0.8625 by 8.0 meters
(0.8625)(8.0) = 6.9 m/s^2
Thanks.
Suggested for: Electromagnetic rail gun
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
