Electromagnetic Stress Tensor
  1. Aug 3, 2017 #1
    An electric field E exerts (in Gaussian cgs units) a pressure E2/8π orthogonal to itself and a tension of this same magnitude along itself. Similarly, a magnetic field B exerts a pressure B2/8π orthogonal to itself and a tension of this same magnitude along itself. Verify that the following stress tensor embodies these stresses:
    T = 1/ 8π ((E2 + B2 )g − 2(EE + B B))
    2. Relevant equations
    ##T_{ii}=P##
    3. The attempt at a solution
    ##T_{xx}=P=1/ 8π(\textbf{E}^2 + \textbf{B}^2-2(E_x^2 + B_x^2))=1/ 8π(-E_x^2- B_x^2 + E_y^2+ B_y^2+ E_z^2 + B_z^2)##
    ##T_{xy}=2/ 8π(-E_xE_y- B_xB_y )##
    Why I didn't get a right result? I probably don't understand "a pressure orthogonal to itself". In particular, it means that if E=(Ex,0,0) so in which direction is pressure? I would say in same but there is written orthogonal.
    Please advise.
  3. Aug 3, 2017 #2
    Orodruin
    Staff Emeritus
    2017 Award
    ##T_{xy}## is not a pressure, it is a shear stress component. The correct question to ask is what ##T_{xx}## is when the electric (or magnetic) field is in the ##x##-direction versus what it is when the electric (or magnetic) field is in the ##y##-direction.
  4. Aug 3, 2017 #3
    Ok. So to your question (only in electric field):
    1) ##\textbf{E}=(E1,0,0)##: ##T_{xx}=\textbf{E}^2-2E1^2=-E1^2##
    2) ##\textbf{E}=(0,E1,0)##: ##T_{xx}=\textbf{E}^2=E1^2##
    Second thing is whether I understand stress tensor. So I try to explain what it is ##T_{xx}##: We have defined unit area ##\textbf{a}## as unit vector perpendicular on this area. Let's say ##\textbf{a}=(1,0,0)## (##y-z## plane). Then ##T_{xx}## is force in ##x## direction on unit area ##\textbf{a}## (pressure).
    From that Im confused from results which I have got. Minus pressure? What is wrong?
  5. Aug 3, 2017 #4
    Orodruin
    Staff Emeritus
    2017 Award
    Nothing is wrong. Strains can be both positive and negative. It depends on the force across the area.
    If you think about the stress tensor in regular solid mechanics, it would correspond to pulling vs pushing the material. (The EM stress tensor is just the same!)
Have something to add?
Draft saved Draft deleted
Similar Discussions: Electromagnetic Stress Tensor
  1. Mawell's stress tensor (Replies: 3)
  2. Maxwell Stress Tensor (Replies: 1)
  3. Stress tensor (Replies: 1)
Loading...
