- 3
I'm working on my first assignment in an EM class and I have a couple questions (this might be a long post). Understand I'm a part time student and I live an hour away from the university and work 40+ hours a week... time is limited. I have a 5 problem assignment and a million questions.
1. Homework Statement
1. For a given charge system, the flux density D= r^2sin(theta)ahat_r+sin(theta)cos(phi)ahat_phi C/m^2. Determine
a)the Charge density at point (1m,45 deg, 90 deg)
b)Find the force on a point charge of 1nC located @ (1m,1m,2m)
2. Homework Equations
a) Plug the point into the flux density?
b) convert spherical to cartesian coordinates find R(trig) and coulombs law for charges in free space 9x10^9(Q_1Q_2/R^2)
3. The Attempt at a Solution
a)so from my understanding a charge density requires a surface area, I am supplied with a point so I thought I'd just put the point in the equation and evaluate from 0 to 1 0 to 45 and 0 to 90... everything cancels but root2/2 which I believe is my answer but I have a point not a surface area.
b)I find R to be root6 using the given charge and the found charge from the previous part put into coulombs law yields 3root2/4 N
The next question is a potential quesiton and I'm lost
The potential field with Epsilon_r = 10 is V=12x^2y find E, P, and D
I don't know where to begin,
3) a square conductive loop 10cm/side is centered at origin carries 10mA current clockwise viewed from the +z direction find the magnetic field intensity at point (0,0,10)
I have sketched it out and found the distance from the point to the corner to be root110 and the shortest point to the line to be 5root2, all the evaluations I can find that come close to this problem all use circles around the point not squares... I'm lost
it sound's like and Ampere's Law problem
intH dot dl = I enclosed
4) Given the magnetice field H=3y^2ahat_y A/m find the current passing through a square in the xy-plane that has one corner at origin and the opposite corner at (2,2,0)
sounds like the opposite of the last problem still stuck
5) in a given region of space, the magnetic vector potential is given by A=5cos(pi y)xhat+(2+sinpix)zhat (Wb/m) determine B and flux passing through a square loop with 0.25 m long centered at the origin of the xy plane and its edges are parallel to the x and y axis.
I haven't dug into the lecture notes and book for this one yet this is due next monday... like I said it's my first assignment and we haven't worked any practice problems in class. I want to understand the correlations between current and magnetic field... that would help with 3&4. Any direction on this assignment would be greatly appreciated.
Thank you
David
Thank you
David
