Calculating the Angle of an Electron Passing Between Charged Plates
In summary, the conversation discusses an electron being accelerated horizontally in a television picture tube and then passing between two plates with a potential difference. The goal is to find the angle at which the electron will be traveling after passing through the plates. The solution involves using equations for energy and electric fields to calculate the electron's speed before and after passing through the plates, and then using mechanics and movement to find the angle.
crosbykins
53
An electron is accelerated horizontally from rest in a television picture tube by a potential difference of 10,000 V. It then passes between two horizontal plates 5.0 cm long and 1.0 cm apart which have a potential difference of 200 V. At what angle θ will the electron be traveling after it passes between the plates?
-ΔEE = ΔEK
qΔV = 1/2mv^2
-ΔEE = ΔEK
qΔV = 1/2mv^2
√ (2qΔV)/(9.1*10^-31kg) = v
√ (2(1.6*10^-19 C)(10 000V))/ (9.1*10^-31kg) = v
5.92*10^7 = v
-so i calculated the speed of the electron before passes through the plates. i don't know what to do next.. a step-by-step solution would be appreciated, thanks in advance
Suppose that the electric field runs upwards. It's field strength is calculated from E = U/d, where U is the potential difference and d the distance between the plates. The electric force exerted on the electron is F = QE = QU/d. From here on, use what you know about mechanics and movement to find the components of the resultant velocity to find the angle.
1. What is electromagnetism?
Electromagnetism is a branch of physics that deals with the interactions between electrically charged particles and the electromagnetic field. It explains how electricity and magnetism are related and how they can be used to produce and control each other.
2. How does electromagnetism work?
Electromagnetism works through the interactions between electrically charged particles and the electromagnetic field. When an electric current flows through a wire, it creates a magnetic field around the wire. This magnetic field can then interact with other magnetic fields to produce a force or motion.
3. What is the role of electromagnetism in daily life?
Electromagnetism plays a crucial role in our daily lives. It is involved in the functioning of many electronic devices, such as computers, cell phones, and televisions. It is also used in power generation and transmission, transportation, and medical imaging technology.
4. What are the applications of electromagnetism?
Electromagnetism has a wide range of applications in various fields. Some of the common applications include motors and generators, electromagnets, electromagnetic radiation (such as radio waves, microwaves, and x-rays), and magnetic levitation systems.
5. How is electromagnetism related to light?
Light is a form of electromagnetic radiation. It is a type of energy that is produced by the vibration of electrically charged particles. The properties of light, such as its speed and direction, can be affected by electric and magnetic fields, which are the key components of electromagnetism.
