Why Does Changing Magnetic Field Direction Affect Current in a Wire Loop?
In summary, the problem involves a loop of wire in a changing magnetic field and the goal is to find the magnitude of the current through a resistor. The correct answer is 0.052 A, which can be found by correctly calculating the change in magnetic field and using the equation emf = -N (flux / time) to find the voltage.
Destrio
212
A loop of wire of aream 0.32m^2 is palced in a 0.75 T magnetic field. The magnetic field is changed to 0.35 T in the opposite direction in 0.45 s . What is the magnitude of the current through the 15 ohm resistor.
emf = (-1) [(.35T)(.32m^2)-(.75T)(.32m^2)]/(.45s)
emf = .284 V
V = IR
I = .284 V / 15ohm
I = .019 A
.019 is the wrong answer in the multiple choice
the correct answer is supposed to be 0.052 A
Thanks
emf = .284 V
V = IR
I = .284 V / 15ohm
I = .019 A
Thanks
Looks like you have not computed the change in field correctly.
for providing the question and your attempt at a solution. It seems like you have made a mistake in calculating the emf (electromotive force) in your solution. The correct equation for calculating emf is emf = -N(dΦ/dt), where N is the number of turns in the loop and dΦ/dt is the rate of change of magnetic flux through the loop. In this case, N = 1 and dΦ/dt = (ΔBΔA)/Δt = ((0.35T - 0.75T)(0.32m^2))/0.45s = -0.177 Tm^2/s. Plugging these values into the equation, we get emf = -(-0.177 Tm^2/s) = 0.177 V.
Now, using Ohm's law, we can calculate the current through the resistor as I = V/R = 0.177 V / 15 ohm = 0.0118 A. However, this is the current at the instant the magnetic field changes from 0.75 T to 0.35 T. To find the average current over the entire 0.45 seconds, we need to use the average emf, which is half of the initial and final emf (since the change in magnetic field is linear). So, the average emf is (0.177 V + 0 V)/2 = 0.0885 V. Using this value in Ohm's law, we get the average current as I = 0.0885 V / 15 ohm = 0.0059 A.
Therefore, the correct answer is 0.0059 A or 0.006 A (depending on the level of precision required). I hope this helps to clarify the solution for you. Keep up the good work!
1. What is electromagnetism?
Electromagnetism is a branch of physics that deals with the study of the interaction between electrically charged particles and the resulting electromagnetic fields.
2. What are the main properties of electromagnetism?
The main properties of electromagnetism include electric and magnetic fields, electromagnetic radiation, and the principles of electric charge and current.
3. How does electromagnetism impact our daily lives?
Electromagnetism plays a crucial role in many aspects of our daily lives, such as electricity and magnetism, communication technologies, and medical imaging.
4. What are some real-life applications of electromagnetism?
Some real-life applications of electromagnetism include electric motors, generators, telecommunication devices, MRI machines, and particle accelerators.
5. What are the fundamental laws of electromagnetism?
The fundamental laws of electromagnetism are the Maxwell's equations, which describe the relationship between electric and magnetic fields, and the Lorentz force law, which relates the force on a charged particle to the electric and magnetic fields it is in.
