Electron/positron and photon
  1. Apr 3, 2014 #1
    A gammaphoton with a frequency of 5,49*10^20 Hz passes by near a nucleus, and turns into a electron/positron pair. The electron has an kinetic energy of 1,20*10^-13 J. How much kinetic energi is in the posistron?(we can neglect the energyexchange with the nucleus)
    3. The attempt at a solution
    Ive tried to solve this using this formula but i get a negative answer:
    hf=2E+Ekp+Eke => Ekp=hf-2E-Eke
    Where Ekp is the kinetic energi of the positron, "hf" is the energy of the photon, "E" is the rest energy of the electron and "Eke" is the kinetic energy of the electron.
    I get that Ekp=-1,64*10^-10 J. This isnt right?
  3. Apr 3, 2014 #2
    The formula is correct. You must've made a mistake in your calculation.
  4. Apr 3, 2014 #3
    lightgrav
    your mistake is in the Units ... 1 Joule is 1 kg m2/s2 , so your electron mass must be in kg.
  5. Apr 4, 2014 #4
    As far as i can understand, the energy in the photon is not enough to create a electron/positron pair?
    hf<2E
    And therefore the problem doesnt have an answer?
  6. Apr 4, 2014 #5
    Curious3141
    You're wrong, the problem does have an answer, which I just found. So we can be sure the problem is correct.
    Your equation is also correct, so the error must lie in your working.
    Unless you show this working, in detail, noone can help you further.
  7. Apr 4, 2014 #6
    Ekp=hf-2E-Eke
    Ekp=6,63*(10^-34)Js*5,49*(10^20)Hz - 2*9,1094*(10^-31)kg*(3,00*(10^8)m/s)^2 - 1,20*(10^-13)J
    Ekp=8,00178*10^-14J
    I just kept entering the wrong exponent in C^2.
  8. Apr 4, 2014 #7
    Curious3141
    What I got too.
    Here's a tip: Google calculator is your friend. Take a look at this: https://www.google.com.sg/search?q=...+-+2*mass+of+electron*c^2+-+1.2E-13J&safe=off
    Just enter your expression as a query next time and Google works everything out, physical constants, units, etc. all inclusive!
  9. Apr 5, 2014 #8
    Thanks!
Have something to add?
Draft saved Draft deleted
