I Electron properties
  1. Mar 21, 2016 #1
    We can deflect a moving electron using an electric field or using a magnetic field. In order to obtain the same deviation, when the energy we should use is higher? Or, in other words, the "electric" or the "magnetic" property is stronger?
  3. Mar 21, 2016 #2
    DrClaude
    Staff: Mentor
    What about conservation of energy?
  4. Mar 21, 2016 #3
    Khashishi
    Take a look at https://en.wikipedia.org/wiki/Lorentz_force
    For electrons moving less than the speed of light (always the case), the electric force is stronger. But for relativistic electrons, the forces are about equal.
  5. Mar 21, 2016 #4
    Vanadium 50
    Staff Emeritus
    Education Advisor
    2017 Award
    Only if B = E in those particular units.
  6. Mar 22, 2016 #5
    I try to choose the "cheapest energetic" way to deflect an electron, based on its known interactions. The electron has, also, a mass. Hypothetically, I could obtain same deflection as in previous case using this time gravitational attraction of another mass. How can this mass be compared with previous cases in terms of energy effort?
  7. Mar 22, 2016 #6
    DrClaude
    Staff: Mentor
    Let me repeat myself: What about conservation of energy?
  8. Mar 22, 2016 #7
    I understand. To obtain a certain same deviation, I have use the same energy, no matter what form it has.
  9. Mar 22, 2016 #8
    DrClaude
    Staff: Mentor
    Yes :smile:
  10. Mar 22, 2016 #9
    sophiecentaur
    2017 Award
    I need a bit of help with this. No work need be done on an object if its motion is circular. If we had a fixed pivot and a length of string, the Force X Distance would be zero. Where is the difference with circular motion in a magnetic field? Or are we discussion the Energy needed to set up the field?
  11. Mar 22, 2016 #10
    Khashishi
    Yeah. That's the case in any reasonable system of units, in which electricity and magnetism are unified. Kind of hard to talk about an electromagnetic field, when the electric and magnetic fields have different dimensions.
  12. Mar 22, 2016 #11
    David Lewis
    As far as deflecting electrons, if you have high voltages handy, electric fields are usually a good option. But if it's easier to provide high currents then electromagnets might be a better choice. Neither type of force field is intrinsically stronger.
  13. Mar 22, 2016 #12
    When the electron pass between the plates of a polarized (ideal) capacitor, the electric field modifies the trajectory of this electron. One billion electrons can follow and the capacitor field will be unchanged. Some work is done. Where comes this energy from?
  14. Mar 22, 2016 #13
    ZapperZ
    Staff Emeritus
    Education Advisor
    Why isn't this obvious that it comes from the E-field? Turn off the field, no deflection.
    Zz.
  15. Mar 23, 2016 #14
    I can not turn off the field, because it comes from the electrons of one plate and the ions of the other plate, and their number is not changed, no matter how many free electrons cross this field.
  16. Mar 23, 2016 #15
    ZapperZ
    Staff Emeritus
    Education Advisor
    You missed the entire point of my post!
    Zz.
  17. Mar 23, 2016 #16
    I tried to understand: Free electrons that cross the capacitor static field change trajectories, so work is done, but the capacitor field rest unchanged forever. Where comes the new energy from?
    Now I think at this scenario: the incoming kinetic electron starts to interact with the capacitor field and transferes energy to capacitor field by disturbing one by one the electrons from the plates, upto the moment when the capacitor field starts to restore its minimum state and pushes out the disturbing electron. So the electron gets no new energy, only a new trajectory - if case.
  18. Mar 23, 2016 #17
    David Lewis
    Correct. No energy need be consumed in deflecting electrons. You could use a permanent magnet, for example. There may be an energy input required to maintain an electric field (replace charge leakage) or magnetic field (resistance of the coil).
  19. Mar 23, 2016 #18
    ZapperZ
    Staff Emeritus
    Education Advisor
    This is incorrect for electrons in electric field, and certainly not true for uniform electric field such as that found in between parallel plate capacitors. The electrons gain kinetic energy from the E-field. This is similar to projectile motion in uniform gravitational field. So it isn't just a change in trajectory, as is the case for uniform magnetic field. There IS KE change! It is how we accelerate charged particles in particle accelerators.
    Zz.
Have something to add?
Draft saved Draft deleted
Similar Discussions: Electron properties
  1. The electron (Replies: 12)
  2. Friction Properties (Replies: 1)
  3. Intensive Properties (Replies: 17)
Loading...
