How Are Electrons Introduced into Dielectrics Beyond Particle Accelerators?
In summary, using a particle accelerator to blast electrons into a dielectric can create a method for getting electrons into the dielectric. There are other ways to get electrons into a dielectric other than using a particle accelerator.
nlantz
So I have seen some people doing making lichtenberg figures using a particle accelerator to blast electrons into a dielectric where they get stuck until the dielectric breaks down.
Here is an example http://www.capturedlightning.com/
Are there other ways to get electrons into a dielectric other than using a particle accelerator?
Damn, I would bet a solid dielectric like glass should fail explosively under such stress...oo)
Yes. A pointed electrode can be melted into a transparent polymer, such as acrylic (polymethylmethacrylate), epoxy, or polycarbonate and a flat electrode applied to the opposite side of the polymer. When the pointed electrode is energized from a HV AC source or from a pulsed HV source, charges will be injected into the nearby dielectric region around the point (where the electrical field is strongest) forming an area of space charge within the nearby dielectric. The space charge regions may suddenly discharge back to the electrode during removal or reversal of the applied voltage, a process called "charge detrapping". These detrapping events, or "partial discharges" within the polymer permanently damage the dielectric. Successive partial discharges create growing microscopic hollow tubules within the dielectric that have partially-conductive walls. The newl-formed tubules extend and concentrate the electrical fields at tubule tipe, injecting charge into more distant regions of dielectric material. Under repetitive charge injection and detrapping events, the tree channels grow and branch, eventually forming a 3D complex electrical tree within the polymer that originates from the pointed electrode, extending a significant distance into the polymer. Over time, the tree grows roughly in the direction of the opposite electrode. It may eventually completely propagate to the opposite side, culminating in complete dielectric failure. If tree growth is stopped before complete breakdown, the result is a 3D electrical tree that may have longer branches (called a "branch tree"). Branch trees typically develop under under positive DC, positive pulses, or lower voltage AC. Shorter and denser "bushy trees" tend to develop under HV negative pulses, under higher frequency AC, or under higher AC voltage excitation. Although these electrical trees are smaller than trees created using a particle accelerator, they are every bit as detailed and the branched trees have similar fractal dimensions.
@BertHickman, very interesting. Do you know if other solid dielectric materials plates behave like that under the HV pulses?
Yes, there are other ways to introduce electrons into a dielectric material. One common method is through the application of an electric field. When a high voltage is applied to a dielectric material, it can cause electrons to be pulled from the surrounding air and become trapped within the material. This is known as the corona effect.
Another method is through the use of a plasma discharge. When a gas is ionized and turned into a plasma, it can release electrons that can then be attracted to and trapped within a dielectric material.
In addition, certain chemical reactions can also cause the release and trapping of electrons within dielectric materials. For example, in electrophotography, a photoconductive dielectric material is used to trap electrons released by a photoconductive layer, creating an image.
Overall, while a particle accelerator may be a more powerful and controlled way to introduce electrons into a dielectric, there are other methods that can also achieve this.
1. What is a dielectric?
A dielectric is an insulating material that is used to separate two conductive materials in an electrical circuit.
2. How do electrons behave in a dielectric?
Electrons in a dielectric are bound to their atoms and are not free to move, unlike in a conductor where they can move freely. The presence of a dielectric material in an electrical circuit reduces the overall movement of electrons and increases the electric field.
3. What is the role of electrons in a dielectric?
The role of electrons in a dielectric is to create polarization. When an electric field is applied to a dielectric, the electrons in the atoms become displaced, creating an electric dipole moment. This results in a net electric polarization of the material.
4. How does the dielectric constant affect the behavior of electrons in a dielectric?
The dielectric constant, also known as the relative permittivity, is a measure of the extent to which a material can store electrical energy. A higher dielectric constant means that the material can store more energy and therefore, the electrons in the dielectric will experience a stronger electric field.
5. Can electrons move through a dielectric?
No, electrons cannot move through a dielectric as they are bound to their atoms. However, the electric field created by the dielectric can influence the movement of free electrons in a nearby conductor.
  • Atomic and Condensed Matter
  • Quantum Physics
  • DIY Projects
  • Electrical Engineering
  • Electromagnetism
