Do Electrons Lose Heat? Answers to Questions Explained
In summary, electrons do not have heat as a property, but they can interact with their surroundings and lose energy in the form of light. When cooled, the electrons in a metal move slower and have a lower average speed, resulting in a decrease in energy levels. The application of an electric or magnetic field can alter the distribution of energy states in the electrons, causing a change in their behavior. The Stark effect and Zeeman effect are two examples of how electric and magnetic fields can affect the behavior of bound electrons in bulk atoms.
Northprairieman
33
Do electrons lose heat? If they do, how do they do it? Bremstrahlung for free electrons and going down to a lower energy level for bound electrons? If you had say a metal and cooled it down, would the electrons move slower or just jump to lower energy levels and lose photons?
Heat is a bulk-property - individual electrons don't have heat.
A cooler metal has more electrons in lower energy levels. This means that the electrons have a lower average speed.
The electrons in the metal lose energy by interaction with their surroundings... that means electromagnetic so, basically yes, they shed energy as light.
Likes 1 person
What effect does an electric field have on a bound electron? Does it slow it down or affect its orbit in any other way? Does an electric field cause an electron to move to another energy level?
What effect does a magnetic field have on a bound electron? Does it slow it down or affect its orbit in any way?
An applied electric or magnetic field alters the Hamiltonian ... so the distribution of the energy states changes.
The effect depends on the exact situation.
Likes 1 person
Within a metal, electrons can be treated as a gas; a kinetic model first developed by Drude ~1900.
Such a gas has a very low heat capacity (confirmed by experiment), and sheds kinetic energy quickly until the electron gas and the surrounding material reach equilibrium temperature.
Most of the shed energy is in the form of phonons (quantized sound). The moving ("free") electrons are not bound to individual atoms ... they are coupled to the bulk of the metal crystal, and move quite freely. These are your carrier electrons, which make up the conduction band.
This is most easily seen in far-from equilibrium systems as when an ultrafast laser pulse is absorbed by a thin metal film: the electrons, having a much smaller mass, are rapidly accelerated, and their thermal energy increases in less than a picosecond, resulting in a two-temperature system consisting of (1) the hot electron gas, and (2) the metallic ion cores. Depending upon the electron coupling constant for the metal ballistic (very hot) electrons may easily be emitted, or may be heavily suppressed.
You can find literature on this by searching Google Scholar for "electron two temperature model".
Note: I did my doctoral thesis on this topic, measuring the phonon distribution across different crystal directions. The cooling curve is the typical exponential thermal decay as the electron gas and the metal temperatures equilibrate. For a purely optical experiment one sees changes in optical reflectivity, which is a measure of the surface electron density.
Likes 1 person
Likes 1 person
1. Do electrons lose heat?
Yes, electrons can lose heat through a process called thermal conduction. This happens when electrons transfer heat energy to other particles, such as atoms or molecules, through collisions.
2. How do electrons lose heat?
Electrons lose heat through thermal conduction, where they transfer heat energy to other particles through collisions. They can also lose heat through radiation, where they release energy in the form of electromagnetic waves.
3. Is heat loss by electrons significant?
The amount of heat lost by electrons depends on various factors such as the material they are in, the temperature difference, and the material's conductivity. In some cases, the heat loss by electrons can be significant, while in others, it may not be significant.
4. Can electrons lose heat in a vacuum?
Yes, electrons can lose heat in a vacuum through radiation. Since there are no particles for them to transfer heat to through collisions, they release energy in the form of electromagnetic waves to cool down.
5. How does heat loss by electrons affect electronic devices?
Heat loss by electrons can affect electronic devices in several ways. Excessive heat can cause damage to the components, affecting their performance and lifespan. It can also lead to inefficiency and increased energy consumption, which can be costly. Therefore, proper heat management is crucial in electronic devices to ensure their optimal functioning.
  • Electromagnetism
  • Quantum Physics
