Electron's magnetic behavior
In summary: UNLIMITED.[/QUOTE]In summary, the electron has a magnetic orientation, which is tiny in comparison to the strength of its electric charge. The electron also has a magnetic moment, which is unlimited.
gespex
56
Hello all,
I have a few questions regarding the magnetic charge of an electron. First of all, I read an electron behaves like a bar magnet, which would suggest the south-pole of one electron would attract the north-pole of another electron. However, electrons also repulse each other. So what does this mean? Is the repulsing force just a lot stronger than the attracting force?
Also, imagine two electrons, their north poles closest to each other, at a certain distance. What is the repulsing force between the two?
Thanks in advance,
gespex
Hi gespex,
Yes, what you are saying is true, although in physics we usually do not talk about magnetic poles, instead we talk about magnetic moments and the interaction between magnetic moments. A monopole (magnetic pole) is a single point containing magnetic "charge" from which magnetic flux lines emanate; in the currently accepted model for electromagnetism which is based on Maxwell's equations, these do not exist. A magnetic moment, rather than being a single point, defines a direction in space, and carries no magnetic "charge." Furthermore the electron is a quantum object, and its magnetic moment is proportional to its spin (its intrinsic angular momentum).
Two electrons will interact via electrostatic force, which causes them to repel. They will also interact via the magnetic interaction, which is usually called the hyperfine interaction, which causes their spins to align.
Hope this answers your question!
[I read an electron behaves like a bar magnet, which would suggest the south-pole of one electron would attract the north-pole of another electron./QUOTE]
What primarily characterizes an electron is it's electric charge...and of course, mass. It DOES have a magnetic orientation, and that becomes noticeable, for example, when electrons become crammed together as in energy levels around a nucleus. But it is a SMALL effect compared with the strength of electron charge.
http://en.wikipedia.org/wiki/Electron_spin says this:
The electron is a charged particle. Its angular momentum comes from two types of rotation: spin and orbital motion. From classical electrodynamics, a rotating electrically charged body creates a magnetic dipole with magnetic poles of equal magnitude but opposite polarity. This analogy holds as an electron indeed behaves like a tiny bar magnet. One consequence is that an external magnetic field exerts a torque on the electron magnetic moment depending on its orientation with respect to the field.
Note the word TINY...that means "weak"...
1. What causes an electron's magnetic behavior?
The magnetic behavior of an electron is caused by its intrinsic property known as spin. This spin creates a magnetic moment, which is a tiny magnetic field associated with the electron.
2. How does an electron's magnetic behavior affect its movement?
An electron's magnetic behavior affects its movement by interacting with external magnetic fields. This can cause the electron to accelerate or change direction, depending on the direction of the external magnetic field.
3. Can an electron's magnetic behavior be changed?
Yes, an electron's magnetic behavior can be changed by applying an external magnetic field. This can cause the electron's spin to align in a different direction, altering its magnetic moment.
4. What is the relationship between an electron's magnetic behavior and its charge?
An electron's magnetic behavior is not directly related to its charge. However, the magnetic moment of an electron does interact with other charged particles, such as protons, which also have a magnetic moment.
5. How is an electron's magnetic behavior used in technology?
An electron's magnetic behavior is used in various technologies, such as magnetic storage devices (like hard drives), magnetic resonance imaging (MRI) machines, and electric motors. The ability to control and manipulate the magnetic behavior of electrons allows for the development of these technologies.
  • Quantum Physics
  • Quantum Physics
  • Classical Physics
