Electrostatic Force
  • Thread starter undrcvrbro
A 1.4*10-9 C charge is on the x axis at x = -2.0 m, a 7.0*10-9 C charge is on the x axis at x = 2.5 m. Find the net force exerted on a 4.0*10-9 C charge located at the origin.
F=k(q1*q2) / (r^2)
k= 9*10^9
I simply took the difference of the two Forces existing between the central charge and each end of the axis.
I took:
F= (9*10^9)(1.4*10^-9)(4.0*10^-9) / (2)^2
and then subtracted it from:
F= (9*10^9)(7.0*10^-9)(4.0*10^-9) / (2.5)^2
But that obviously isn't correct, because Web assign gave me a big red X when I plugged the answer in. Any help is greatly appreciated!
Answers and Replies
Kurdt
Staff Emeritus
Force is a vector and the total force on the central charge can be found using vector addition. Work out what direction each force is acting and the answer should become apparent.
Yes, that's what I thought, but I got the wrong answer...I'm missing something here.
Because all vectors are on x axis, and its asking for the net force on the center charge, wouldn't I just take the force imposed on the center from the left, and subtract it from the force between the center and the right charge? It seems too simple.
Kurdt
Staff Emeritus
Because force is a vector it matters what direction it is acting in. Since all charges are positive the force is going to be repulsive. Draw a diagram if it helps.
So the left charge will produce a force that wants to push the centre charge to the right. The right charge will produce a force that wants to push the centre charge to the left. If we take right as the direction of the unit vector on the x-axis, then the force from the left charge will be a positive factor multiplied by the unit vector. The force from the right charge will be a negative factor of the unit vector. Now apply vector addition.
Related Threads on Electrostatic Force
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
